ASE master tech/machinist
What's the difference between doors.
I have a 72, the upper door hinge area is rusted beyond my repair capabilities. I have a few 67-71 doors around, but no 72's. I know the wing window latches were different on the 67's, and the door panels are different, if the chrome strip is removed will the 72 panels fit?
Re: What's the difference between doors.
i think and i'am sure some one will correct me , but 72 had reinforcements just below the vent window( the small screw just below) and 67-71 didn't, plus the door panel holes are bigger cause the67-72 were screwed in instead of push pinned
Yeah,visually the only difference will be the lack of a dimple and screw below the divider bar.You could imitate that,though.You will need to swap the mechanicals because`72s have longer shafts for the window winders and door handle due to the`72-only interior panels.You can swap wing vent glass/latch out of the`67 door and use 68-72 pieces.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-22-2008 at 07:16 AM. |
![]() Join Date: Jan 2002
The 67's use a different outside door handle. You have to use 67 door handles only. I think all of the 67's are like this. The 68-72 handles will not work unless you modify the inside of door.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
