Old 12-22-2008, 03:40 AM   #1
68c10owner
68c10owner's Avatar
heater controls
does anyone repop heater controls for a 84? I`ve only seen the ones in LMC and they were fro 74-78 IIRC. If nobody makes them for my 84 can i install the earlier ones? I don`t care that they won`t look rihgt I just want them to work correctly. My defrost lever jams up a bit when moving from heater to defrost and I`m afraid I`ll snap it off like the fan switch. My old 75 GMC had the same problem only it was stuck on heater.
Anthony
68c10owner is offline   Reply With Quote
Old 12-22-2008, 09:31 AM   #2
Tony@AirRideTech
Junior Member
Re: heater controls
you can still get those over the counter at a good parts store like Napa... if you can not find them there, I know that Year One has them.
Tony@AirRideTech is offline   Reply With Quote
Old 12-22-2008, 10:35 AM   #3
68c10owner
68c10owner's Avatar
Re: heater controls
Thanks. I didn`t know I could get just the levers. Well if I replace the levers whats to stop it from doing the same as it is now? I`d like to have smooth working levers that I don`t have to worrie about breaking off when I move them back and forth.
Anthony
Old 12-22-2008, 10:43 AM   #4
manimal
manimal's Avatar
Re: heater controls
check out Brothers Trucks.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 12-22-2008, 11:33 AM   #5
68c10owner
68c10owner's Avatar
Re: heater controls
-Lance
Thanks. I just looked and the only one they have for my year is for A/C which I don`t have. Will the 81-82 heater only style work in my 84? Is the wiring the same? Should just plug in right? Another thing is I do plan to add a Vintage air A/C kit down the road. Does the A/C controls have a different harness? Can I use it with my heater only till I can afford to swap in the A/C?
Anthony
Old 12-22-2008, 01:30 PM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: heater controls
Found a part number for the heater controls for a NON-A/C 1991 suburban that shoud work for you. part number is 16034561
Only one dealership shows to have one in stock and that is...
DANIELS CHEVROLET-BUICK-PONTIAC-GMC SUPERSTORE
(478)237-4111
365 E MAIN ST
HWY 80 & 56
SWAINSBORO, GA 30401
Give them a call and see if they do indeed still have it and what they want for it. It could very well work for what you need.
Dave
Your parts guy in the tropical land of ALASKA!!!! High to day of 30 degrees!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
