Old 12-22-2008, 04:28 AM   #1
neto
neto's Avatar
Hei Coil burnt x 2
Would a lack of grounds burn a coil? It rained today and was wondering if I lost ground somewhere? Does any one know where to ground and what to ground besides everything? 73 truck, converted to hei, was running fine till this morning when it wouldn't start. I check all connections and turned out to be the coil. I replaced the coil and it started right up. Moved it a bit then started it once more and that's all she wrote. I have another coil but don't want to put it in yet until I figure what happened.
Thanks.
neto is offline   Reply With Quote
Old 12-22-2008, 09:30 AM   #2
Tony@AirRideTech
Junior Member
Re: Hei Coil burnt x 2
yes it can.....
Tony@AirRideTech is offline   Reply With Quote
Old 12-22-2008, 12:26 PM   #3
James McClure
One shot, one kill.
neto, check and see if the "coil grounding tab" is still in the cap or if it fell out or was discarded by accident. If tab is missing, get one from NAPA or just ground the coil with a wire, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 12-22-2008, 12:41 PM   #4
seanconnery
yeah, the coil grounding tab can be tricky to keep in its place when replacing the coil. one of the 4 coil screws that fasten the coil to the distributor cap itself actually holds that tab and provides a ground as well. so theoretically, you could have your ground wire with the spade terminal connector hooked up to the coil grounding tab properly, but if the grounding tab isn't being held by that screw, you'll get nothing and scratch your head too. i've been there. when you replace the coil, before you hook up the spade terminal ground, turn the ignition on and check for voltage with a multimeter. if you get voltage, then the grounding tab is properly seated in the distributor cap and you should be golden. hope this helps.
Also, if you've upgraded to something like one of those ACCEL super coils and you're still using the factory HEI module, it will work for a few starts, then the ACCEL coil will fry the module. That has also happened to me. Either use all factory parts, or all ACCEL parts. you cant mix aftermarket coils and stock modules. again, hope this helps.
G to the M to the C......fool!
RIP Jerry Reed "The Snowman"
seanconnery is offline   Reply With Quote
Old 12-22-2008, 01:33 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
You did remove the resistance wire for the points distributor right ?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-22-2008, 08:44 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
for the fun of it if a coil is from an aftermarket manufacturer i have seen them do that right off the shelf due to manufacturing defects.. KEM was bad like that
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-22-2008, 09:16 PM   #7
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Sometimes left out is this metal ground tabName:  coil.jpg
Should look like this in the capName:  coil1.jpg
I try to put the ground wire over the ground tab and if its rusty like this.It needs cleaned upName:  coil3.jpg
HEI runs on full 12 volts, No resistor wire at all
powerdriver 1958 is offline   Reply With Quote
Old 12-23-2008, 12:29 AM   #8
neto
neto's Avatar
You guys are amazing!!! OK 2 more questions. Should the 12 volt wire for the coil have continuity to those two areas in the fuse box. Checking to see if a hot wire is grounding which might burn my coil. Continuity checked with battery completely disconnected all fuses out except for the horn. I have cleaned existing ground wires and put two more from block to frame. Changed the altenator clip, put a new coil. The resister wire is gone all the way to the firewall block. The ground wire is on as well as the ground tab. The second question is where the coil goes into. The second picture is how I put the probe then the rubber part with the spring through the hole and finally the coil but in another post I saw that I had it backwards. It should be the rubber first then the probe but seems like it doesn't protrude to touch the metal plate on the rotor. Which way should it be?
Thanks again.
Ernest
Old 12-23-2008, 04:24 PM   #9
neto
neto's Avatar
Well went to pick a part this morning and took apart two hei coil setups to check for what goes in first. First the probe then rubber and finally the coil.
Thanks.
