Old 12-22-2008, 11:01 AM   #1
1969K10
1969K10's Avatar
Heater core air flow
Can anyone tell me where the heater core gets fresh air to heat my cab?
My truck has sat most of the last year +, and I don't have the heat capacity I used to. I'm guessing the air flow is clogged with leaves...
THX
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 12-22-2008, 11:38 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Heater core air flow
THX
My guess it has a mouse nest in it. I think it gets its air from the cowl & yes leaves can get in there too.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-22-2008, 01:09 PM   #3
smoked68
smoked68's Avatar
Yep clean all that crap outta there and you'll be good as new. I took the cover off the heater core under the hood and a shop vac/leaf blower. Messy but none the less effective. Good luck. Mike...
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 12-22-2008, 01:51 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Four screws, as I remember...plus some electrical connections and coolant lines to the heater core.....
Once you get into it, you'll find a lot of opportunties for "stoppage of the air flow". I hope you can find them and clean it out w/o finding other "problems".
Member Nr. 2770
