12-22-2008, 02:50 PM | #1 |
22's on a stepside laid out.
ok ive never done a 67 body style before. but im about to. i need to know can i run 22's with a step side bed. i really dont like the step sides but it belongs to my dad. im gonna try to talk him out of a step side but if not then im stuck with it until i buy it from him. so can anyone out there help me out with this? Thanks.
12-22-2008, 03:31 PM | #2 |
Re: 22's on a stepside laid out.
you're not gonna lay out with a 22" on a stepside with the stock width rear-end. tires gonna interfere with the inside of the stepside fenders.
12-22-2008, 06:34 PM | #3 |
ok cool. that means a fleet side. woo hoo.
12-23-2008, 01:49 AM | #4 |
THE TOY STORE
googe image it. i seen a pro-street 67 step that was lay'n rocker he cut and made the stepside finders taller and it looked badass
12-23-2008, 02:32 AM | #5 |
you can build a 67 stepside
on 22 inch wheels and make it lay out. You will have to raise the fenders up to the bottom of the bed rails.You will have to a step knotch and raise the bed floor.You can run irs on air and leave the bed floor where it is and just make room for the a-arms. This is more money to do it that way.If you run a solid rear axle you will have a large driveshaft tunnel running thru the cab.You can achieve this with the stock frame and purchase front crossmembers from porter built or sucide or if you want a custom ifs you can choose Scotts superslam that will have up to 12 inches of travel and setup to lay out with 22 inch wheels.If you want a custom tube chassis we can offer one of our scotts superslam chassis to lay out front and rear. Justin www.scottshotrods.cm |
12-23-2008, 09:58 AM | #6 | |
12-23-2008, 11:04 AM | #7 |
THE TOY STORE
24s will nt fit if u wanna lay body
12-23-2008, 06:54 PM | #8 |
12-23-2008, 09:20 PM | #9 |
12-23-2008, 10:58 PM | #10 |
One day...
No they won't fit, well "factory setup". Anythings possible, get creative, start cutting, raise fenders or whatever you can come up with. now the 24's may be a little more tricky to make fit..
12-23-2008, 11:19 PM | #11 |
well i found a set of coys 22's wheels and tires are right at 2000. not bad. atleast i dont think. so thats what im runnin.
Last edited by Shane; 12-23-2008 at 11:37 PM. Reason: can't post Want To Buy posts without first subscribing. Sorry. |
12-24-2008, 02:26 AM | #12 |
THE TOY STORE
no i ment 24s are taller than the bedside
12-24-2008, 10:57 AM | #13 |
One day...
Ya those coys are sweet! I want the 22" gun metal ones for my truck
12-24-2008, 02:11 PM | #14 |
12-24-2008, 03:14 PM | #15 |
If folks can get 24s on s10s its possible for a fullsize. But not a step side bed. Theres a local guy whos 20s are cutting into his step sides fenders at the top badly. So they will need to be raised a good big. But with a shortened rear end and the right backspacing 24s should be possible on a fleet side
12-24-2008, 05:45 PM | #16 | |
12-24-2008, 06:40 PM | #17 | |
12-24-2008, 07:19 PM | #18 |
Knuckle head
Going low with a Stepside is tough. You could raise your fenders like the other guys were saying, but if you are a guy that pays close attention to body lines it will be a little messed up. I have attached a link to a fella that was having the same problems with 20's. I dig Stepsides but laying frame with a fleet appears to be less of an a$$ pain.
Just my .02 http://67-72chevytrucks.com/vboard/s...=282113&page=3
Adam '71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. |
12-24-2008, 08:38 PM | #19 |
THE TOY STORE
go measure and see how tall the bedsides are.
12-24-2008, 09:21 PM | #20 |
I would section the fenders & add height to the top section (keeping the bodyline constant) before raising the entire fender.
12-24-2008, 11:44 PM | #21 |
thanks for the link. but ive decided to find a fleetside. im glad u guys are giving me some feed back. as said before ive never done one of these body styles. so thanks.
12-25-2008, 01:27 AM | #22 |
One day...
I would keep the body line and add just above it, and if you take the slope out of the 60's model beds it would be possible to get 22's i believe, but thats a lot of reworking rear fenders. Well if your going to get a fleet and just do it that way thats cool, post up some pics when you get it
12-25-2008, 07:22 PM | #23 | |
12-26-2008, 08:59 PM | #24 |
Seņor Member
I think I just threw up a little in my mouth.
12-26-2008, 10:39 PM | #25 |
