12-22-2008, 03:52 PM | #1 |
Junior Member
Testing the waters.... Whats it worth...
I have a 68 short wide bed that I started working on a couple years ago. So far i have done the tare down work. The front clip is off, the front and rear windows are gone and the truck is gutted. It is basically ready for media blasting and then primer.
The truck has some rust in the cab corners and rocker panels. I have patch panels for both the original hood is fair and the emblem holes have been filled. Hood hinges are shot and need replaced and the drivers door is tweaked and will probably need to be replaced. Other then that the frame is solid the bed is straight as well as the cab, the metal floor is ruff and has a couple areas that have some rust. Here are a couple pics of the truck before and during the tare down. It needs to go!!!! Make me a reasonable offer and lets see what we can do!!! I guess I will start asking at $1250 OBO and go from there!!!!!! Also I have a ton of other parts including a 5.3L out of an 02 chevy, body mounts, gauges, tilt column, disk brake conversion, and lots of other stuff that I will list here soon. Last edited by bigo181979; 12-22-2008 at 07:11 PM. |
12-22-2008, 03:58 PM | #2 |
Re: Testing the waters.... Whats it worth...
Just the rolling chassis.? $800?
12-22-2008, 04:08 PM | #3 |
I believe you have to post a price with an ad here but I would be interested in the rolling body as is after you have a price in mind.
Or just move this over to the WIW "What's it worth" section for opinions. Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" Last edited by HOTFUN; 12-22-2008 at 04:10 PM. Reason: added the WIW column suggestion |
12-22-2008, 04:11 PM | #4 |
Formerly- 1972SuperCheyenne
Possibly interested in the 5.3. Does it have trans. also? Thanks
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
12-22-2008, 06:48 PM | #5 |
Junior Member
Ok so I guess if I need to put a price on the rolling chassie lets say $1250 or BEST OFFFER...
I do not have a tranny for the 5.3l but I do have the harness and computer $1000 or best offer for it. The front disck brake conversion is based on the following thread, you use parts from 88-98 style chevy and 3/4 ton lowers off our 67-72's their is more info on here and here is a thread about it http://67-72chevytrucks.com/vboard/s...d.php?t=177230 comes with all moog parts $375 plus freight. The tilt column is from a Van $150 plus freight. EVERYTHING IS BEST OFFER AND EVERYTHING MUST GO!!!!!!!!!!!!!!!! Last edited by bigo181979; 12-22-2008 at 07:08 PM. |
12-22-2008, 07:12 PM | #6 |
Junior Member
Also I have the 350/350 combo that was in the truck if anyone wants it $100 it ran when pulled and tranny has B&M shift kit.
12-22-2008, 07:45 PM | #7 |
Any more info on the 5.3? What year, miles, etc.
12-22-2008, 10:26 PM | #8 |
Restoration Virgin!
what kinda of gauges you got?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
12-23-2008, 04:19 AM | #9 |
Junior Member
The 5.3 came out of my 02 silverado, we put a 6.0 in it . it had 102 k when removed, oil was changed every 5 k with mobile 1 and there were no problems with the motor when it was removed, I just wanted more power.
As for the gauges they are autometer C2 series. I purchased them to fit in the following billet panel: http://www.truckbuildermagazine.com/...53802A8EF0A2EC which I have available for sale as well as the matching glove box door! $225 for guage panel and $150 for door plus shipping. Both are still in the box! I will have to see what guages I have exactly but I know i have speedo, tach, gas level, voltage, water temp and oil, but i dont remember if it is pressure or temp on the oil. I also have a boost guage that matches as well... I spent well over $700 on the set of guages make me an offer and we will see. Last edited by bigo181979; 12-23-2008 at 04:25 AM. |
12-23-2008, 01:46 PM | #10 |
Junior Member
Sold!!!!!!! Along with all parts that i had with it.
12-23-2008, 03:28 PM | #11 |
Congrats on the quick sale. Should we be looking for a build thread from another board member now?
12-23-2008, 11:30 PM | #12 |
how much for the bed?
