Active Member
How long to change out spindles and A arms
I am looking for a time frame to change out my front A-arms with new shafts, spindles, tie rod ends etc.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Hollister Road Co.
Re: How long to change out spindles and A arms
4 - 6 hours if you have the correct tools. 8-10 if you have to improvise.
Provided you dont run into any stuck bolts.
![]() Join Date: Nov 2004
The lower ball joints need to be pressed in (not sure if you knew that or not) but if you have the tools, set aside a saturday and you should have it done
![]() Be careful with the springs!!!! I installed drop spindles in my S-10 (almost the exact same suspension set up) and it took me about 3-4 hours. No ball joint or tie rod changes or anything, just a spindle swap. I did it in a parking lot though... Best of luck, are you dropping it too?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-22-2008 at 05:30 PM. |
Junior Member
Dave's estimate is about what it took when my son and I did it.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
a full weekend if you take the time to clean derust paint grease and detail the job /
but mostly if you start fri night it should be ready for the alignment shop on monday
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 12-22-2008 at 05:31 PM. |
