Old 12-22-2008, 04:55 PM   #1
NYC-10
screamin eagle
NYC-10's Avatar
surprise at the machine shop
sent my heads to the machine shop and it turns out they are 307 heads.My block is a 350.Was it common practice to put smaller heads on a 350?Turns out my friend has a set of 350 heads so I will use them instead.
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 12-22-2008, 04:59 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: surprise at the machine shop
it depends. Some have a smaller chamber increasing the compression. 305's on a 350 is a common swap.
dwcsr is offline   Reply With Quote
Old 12-22-2008, 05:33 PM   #3
What size valves and what cc were they?
Old 12-22-2008, 09:37 PM   #4
72armyswbtruck
72armyswbtruck's Avatar
Not super uncommon for their to be 307 heads on a 350, look at the harmonic balancer. You might be suprised there as well.
But they have definitely been swapped out at sometime.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-22-2008, 09:40 PM   #5
NYC-10
screamin eagle
NYC-10's Avatar
you think they would swap that as well?I'll have to look tomorrow
SCREAMIN EAGLE
Old 12-22-2008, 09:51 PM   #6
jholley
jholley's Avatar
Depending on what casting your 350 heads are you may be better off with the 307 heads. The combustion chambers are most certainly smaller boosting your compression ratio a bit.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 12-22-2008, 10:01 PM   #7
NYC-10
screamin eagle
NYC-10's Avatar
the casting on the 350 heads are 387 3487
SCREAMIN EAGLE
Old 12-22-2008, 10:03 PM   #8
chevybuldr
chevybuldr's Avatar
Are your pistons flat or dished? If they are dished I would stay with the 307 heads. Keep the compression up there. Are you sure that the motor is a 350? Check the casting number in the back while the heads are off.
chevybuldr is offline   Reply With Quote
Old 12-22-2008, 10:04 PM   #9
66skylarkpost
66skylarkpost's Avatar
the draw back to putting on smaller cid heads are that they typically have smaller valves to clear the cylinder walls and thus smaller ports to maintain velocity
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 12-22-2008, 10:30 PM   #10
NYC-10
screamin eagle
NYC-10's Avatar
block is a 350 I checked the numbers and measured the pistons-It has flat top pistons with a valve relief
SCREAMIN EAGLE
Old 12-22-2008, 11:12 PM   #11
1966gmc
Why does it taste purple?
1966gmc's Avatar
Put some 350 heads on it and you will love yourself.
1966gmc is offline   Reply With Quote
