Old 12-22-2008, 04:56 PM   #1
bbchevy
87 Wanna Be K30
bbchevy's Avatar
88 burban cammed out idle
my buddys 88 burban has a stock motor and all. runs great while driving but idles like its got a 510 lift cam. and usually shuts off at idle in gear.... where should i start?
-scott
Was: 1987 V10 Silverado
TBI 350/700R4/208 with 3.42 gears
Is: A wanna be K30
330hp 350/465/205/D60/14FF with 3.73
hydroboost, 4 Core radiator, electric fans, Centerforce Duel Friction, Locker, 6inch Soft ride lift, etc....
bbchevy is offline   Reply With Quote
Old 12-22-2008, 05:10 PM   #2
justcuz
justcuz's Avatar
Re: 88 burban cammed out idle
Start with the EGR. Plug it off and see if it runs better. If it does then it is either the solenoid, or the valve. The solenoid should not be sending vacuum to the EGR at idle. If that does not fix it check for vacuum leaks, you have a pretty big one if it makes the engine stall in gear. Check the vacuum line to the power brakes and make sure the booster is not leaking. If your brakes work OK then the booster is probably good.
justcuz is offline   Reply With Quote
Old 12-22-2008, 05:11 PM   #3
Tony@AirRideTech
Junior Member
First thing I would look for would be an intake or vacume leak. If it is a holley carb it sounds like the power valve is popped
Tony@AirRideTech is offline   Reply With Quote
Old 12-22-2008, 05:18 PM   #4
justcuz
justcuz's Avatar
Sometimes the EGR valve can be held off its seat by garbage in the intake, especially since I see you are back in the East Coast. In colder weather the condensation will mix with the rich exhaust at startup and cause a buildup that can unseat the EGR at the intake. The junk looks like bits of coal. If it happened suddenly, the EGR is the first suspect. After that start checking vacuum lines.
Old 12-22-2008, 05:31 PM   #5
bbchevy
87 Wanna Be K30
bbchevy's Avatar
cool, ill check it out and let you know what i find. damn tbi
Is: A wanna be K30
Old 12-22-2008, 08:14 PM   #6
68c10owner
68c10owner's Avatar
my truck was doing that recently. I found a hose off at the PCV valve that goes to the canister. Once I put it back on it idles so smooth I can barely tell it`s running.
Anthony
68c10owner is offline   Reply With Quote
Old 12-22-2008, 08:17 PM   #7
hugger6933
I would pull the throttle body and check for varnish in the vac. passages, they have a tendency to get plugged. First, You might also unplug the vac to the PVC valve and run somthing in there to see if it is clear. I have seen many that were completely stopped up and it would cause the driveability problem. Jim
hugger6933 is offline   Reply With Quote
