Drop springs is 3-5 ok without c notch?
Thinking about lowering my first truck. It a 68 swb that we are building for my 15 year old. Had seen the drop springs and noticed they come 1/3 or 3/5. We are using 15 inch aluminum wheels with 60s front and 50s rear. I cant go to the expense of drop spindles and c notches. Whats my best bet?
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Drop springs is 3-5 ok without c notch?
You can run 6 inch rear springs without a notch. I've done it many times.
I have a radical idea!
I lot of people on the board are running 2 1/2" spindles and 1" lowering springs and 6" drop springs in the rear without a C notch. I have my beater truck dropped 3/5" with just springs and it does fine, but they are little harder to align than the drop springs. I have heard of a few people saying that some of the 3" drop springs pop out of the spring pocket when you jack them up.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Yep my 3 inch front drops would almost fall out if there wasnt any pressure holding them down
#5 | |
You won't need a notch, but an adjustable trac bar (panhard bar) is a good idea. It helps to re-center the axle.
So 3/5 springs would be ok by themselfs? And not be too much of a pain? Would it set about level?
#8 | |
Here's my beater dropped 3/5".
thanx
![]() Join Date: Nov 2008
Dont need a notch for a 5-6" rear drop (like everybody is telling u) Here's my
72 cheyenne with a 5" rear (there's still about 3.5 inches of travel between the differential and frame. ![]() Last edited by Puropedo; 10-13-2009 at 02:40 PM. |
ASE master tech/machinist
Heres my old 71 GMC, 3/5, 235/70/15 and the rears were the equivalent to a 31/10.50. The 66 parked behind it had the same drop with custom made torque thrusts, 17x6 front, and 17x12 rears.
My 70 is dropped 5" in the front with springs and modified a-arms. The rear is dropped 6.5" with springs and blocks on the trailing arms. Rode great and never had a problem with 275/60/15 all around. Going with 17's and a 5.3 swap currently.
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB 331 sbc and all the goodies. Under resurection 2001 Vette |
#13 |
![]() Join Date: Aug 2008
Do you have any more pics of the 71 with that drop? Thanks man.
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
#14 |
Mean Green
What brand of rear springs are those? I bought a set of mcgaughy 5" rear spring and it lowered it like 6" to much for me. My 4" springs are just not enough. Looking for a true 5" spring. Also what are you doing for drive line angle?
#15 | |
I've seen too many bad reviews of Mcgaughy and CPP stuff.
#16 | |
Tot Roddin'
![]() Early Classic Enterprises offers some of the best products and service I've seen, and I've never heard a complaint about their way of doing business or products.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 12-23-2008 at 09:02 AM. |
#17 |
you guys are saying 3/5 drop with only coils? im looking at the early classic website, they only offer up to a 2 inch drop with coils in the front.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
#18 | |
Never Ending Projects
As they say, just because you can... doesn't mean you should. YMMV. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#19 | |
#20 |
I wish I was a cowboy
![]() Join Date: Apr 2008
I can't agree on the 6" drop with no cnotch. I agree that you can run a 6" drop spring and still drive the truck, but you'll have like 1/2" clearance between the frame and axle tube.
I have 5" drop springs and 1" blocks, and if I didn't have the notch, I'd have the frame on the axle every single bump I hit. I know it's doable, but you can't really ever expect to haul anything (not even your old springs) anywhere without hearing and feeling that obnoxious bump in the back. This is only my experience, I have heard of lots of people running 6" drops without issue, it just hasn't been my experience. 5" drop in the back shouldn't be a problem even with a light load in the bed. ECE is great, PerfOnline is good (in my experience again), and CPP is not-so-good, mostly because of communication and customer service. Oh, yeah, one more comment: definitely run drop spindles, don't do the 3" drop spring in front. Crappy ride, weird alignment, and weird characteristics around corners - you know the thing where even right after a good alignment, so still get squel around corners, only to the right? Yeah, weird stuff man, get the drop spindles.
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
#21 |
O k thanx guys. I knew yall would steer me straight. Thanx again
#22 |
Mean Green
Early classic stuff is my best bet then. Thank you guys very much.
#23 |
Can you run a 6 inch spring AND a set of 2 inch blocks?
#24 |
You sure can, but you'll definitely need the notch, then. Here's a quick cell pic of why a 6" drop spring probably should have a notch: Also, in the pic below, with this stuff in the bed, I was drooping below the frame/axle clearance height, so with a 6" drop spring and any load, you'd be hitting frame:
#25 |
Alright thanks
