67-72 Addicted
Quick Questions
#1 Just bought a 72 GMC K2500, what gears would be in it, 4.57 or 4.10???
#2 I was looking up info about 2 of my 350's; one is a TBC (1970) and the power ratings come up as 255hp as expected. The second is TRK (1972) and it comes up as 175hp? Are my sources wrong or was there a power drop? #3 I’m picking up another 350 (part of the K2500 deal) its block casting 3970010. I’ve been told its high nickel (it's got the 010) and 4 bolt mains. Thing is it’s a 2 barrel? Was this custom ordered or standard in 69 or something? |
Re: Quick Questions
I would think it would have 4:10 gears
![]() Join Date: Feb 2004
Re: Quick Questions
It could be ordered in almost any gear ratio, let me look at my literature tonight and I will tell you what the options were.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
67-72 Addicted
Re: Quick Questions
I have a list of options here but it is from 1970. Also, on the chart it shows that with a 350 and SM465 there would be 4.57* gears standard, than at the bottom of the chart it says *4.10 were used on 4wd trucks with a 350 and SM465 or TurboHyadra.... So im a little confused. Lol
Restoration Desperation
Re: Quick Questions
There should be a code stamped on top of the axle, passenger side. Mine was pretty faint, but there. Clean it off & use a good shop/flash light & a mirror to find it. I am looking for the link to the codes......
RD |
Re: Quick Questions
Here ya go:
http://www.americanclassic.com/paint.htm Oh, and it is on the axle tube between the rearend & the hub. RD |
Re: Quick Questions
some 350 4bolts were two barell...and some were converted later in there lives.....the 0010 block is indeed the high nickel block and a nice solid foundation to build on..prolly most likely from a truck originally
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster Last edited by heavy71chevy; 12-22-2008 at 11:16 PM. |
Re: Quick Questions
In 1971 the HP ratings changed from gross to net [basically minus the accessories]. They were also lowered by the automakers to cut insurance costs...some much more than they actually were at the flywheel.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
67-72 Addicted
Re: Quick Questions
Went out today to look for the code. I can see where it should be but it is rusted bad enough that i cant make it out... Anyone know for sure what would have come stock? 1972 GMC K2500 350 4 speed. Thanks
Resident Curmudgeon
![]() Join Date: Dec 1999
Re: Quick Questions
4:10 standard from factory with that engine and tranny. I have same setup, the 307 V8 and I6 trucks had 4:56 standard
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
