Old 12-22-2008, 06:32 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
step side help
ok the steps on my step side are rusted through and almost at the point of braking now my question is...is there a place i can buy just the steps or am i gunna have to just reinforce the old steps with diamond plating
pokethesmot is offline   Reply With Quote
Old 12-22-2008, 06:50 PM   #2
74 C-30
Dually Pride
74 C-30's Avatar
Re: step side help
http://store.73-87chevytrucks.com/me..._Code=STEP7387
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 12-22-2008, 07:46 PM   #3
pokethesmot
Re: step side help
Originally Posted by 74 C-30 View Post
now do i have to weld those on or can i just bolt them
Old 12-23-2008, 11:08 PM   #4
tgh117
Crazy
tgh117's Avatar
Re: step side help
LMC also sells them. With which ever ones you go with, you will have to unbolt the old ones and bolt the new ones on. They should bolt into the same holes. Be sure to test fit all the bolts, as you may need to use a uni bit and enlarge a hole or two since they are aftermarket.
Also, you probably will want to replace the step brace also. As is usual withe the steppers, they rust through between the step and the brace, which usually means the brace is junk to. LMC also carries them. Try around page 28 of the catalog. I just got one from them and it was pretty good qualtiy wise. Not quite as good as the GM one I cam across a year ago, but not too bad.
Good luck
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 12-30-2008, 04:26 PM   #5
pokethesmot
Re: step side help
it wont tell me how much shipping is im trying to decide...ether lmc or this one lmc is like $60 total
Old 12-30-2008, 05:50 PM   #6
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: step side help
Support the board venders, just my opinion.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 12-30-2008, 06:22 PM   #7
Nolowrider
Nolowrider's Avatar
Re: step side help
Not to high hi-jack this thread, but.........
I have been looking for the chrome ones forever. I bought a set years ago, but for the life of me I can't remember where.
Nolowrider is offline   Reply With Quote
