Long Fleet Club
It came out of a '92 Chevy truck from what I was told. I put pictures of what I have now and what is with the kit. What do I need to do to get my alt and P/S pump to hook up (see pic below)? Also what is the Black bracket for? If it goes behind the P/S pump and mounts to the front of the block can I cut off the two ears that go to the headers? I know I need a reverse rotation W/P from the same year truck.
![]() ![]() The alt and P/S I have now ![]() ![]()
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 12-23-2008 at 12:37 AM. |
![]() Join Date: Jun 2006
Re: Got my new serpentine system in
Chec out my build thread for a pic of that black bracket with the ears cut off to clear headders. I have the same setup
If you are going with the great upgrade to serp. then I would also get adaptors for the new model PS pump to you stock steering gear, and also rewire it for the new style Alt.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
Long Fleet Club
How do I rewire it? the alt has the plug with it and it just has one brown wire comming out of it. Also where can I get the adapters from?
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
Long Fleet Club
Under Construction
I have heard that summit / jegs sell an adapter that takes it from the old style to the new 1 wire alternator. I will be needing to do this soon. As far as the PS pump. I recall that we are suppose to reuse the hardline, and unscrew the other from the back of the new PS and screw in the line from the old PS pump, so it still mates to the ps gearbox. Hopefully someone will correct me if my oldtimers is kicking in.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 12-23-2008 at 09:09 AM. |
Under Construction
forgot i saved this for future reference: http://67-72chevytrucks.com/vboard/s...d.php?t=233335
Post #6,#7 talk about the adapter we will need.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Feel free to see mine. It's off a 94 truck but should be pretty much the same. I haven't wired my truck yet, but I'm going with a complete Ron Francis Wiring Kit.
Long Fleet Club
I just got everything installed and working great. I lucked out and the P.O. installed a newer style power steering pump so I didn't have to change out the fitting. My truck was already upgraded to an internal regulated alternator so I just had to change the plug and go by the web site I posted above. Right now the P.O. used a light bulb under the hood for the alt to work right later I'm going to put in a resister.
Long Fleet Club
Here are some pictures of my install.
FYI put the passenger bracket on first because it will hit the water pump when you try to slide it on the stud in the head. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
