Old 12-22-2008, 08:20 PM   #1
mekdad
mekdad's Avatar
Aluminum two and three gage panel
$50.00 Shipped to your door with mounting hardware and drilling template for four 1/4-20 studs.Any questions just ask.
you never know what you can do until you have to undo something you have done!
mekdad is offline   Reply With Quote
Old 12-23-2008, 12:01 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Aluminum two and three gage panel
Looks great for those with crazy PO's who cut a hole way too large and even the other bezels won't hide. Fills it in nicely. I will be measuring mine to see if I can use the old style or this and then ordering one of them...Thanks.
If you do the two hole, how were you going to do them...centered or spaced equally?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-23-2008, 12:26 AM   #3
Deuce
Deuce's Avatar
Do you make anything for the heater control hole??
CD Player or Gauge pod??
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 12-23-2008, 12:39 AM   #4
mekdad
mekdad's Avatar
How ever you want it.I will cut one in the morning that will be even spaced,but on these I will offer what ever hole pattern you want,and holes for toggle switches or what any body needs.
I am working on that right now.for gauges or cd players or vinage air controls.
Old 12-23-2008, 12:43 AM   #5
Deuce
Deuce's Avatar
I'd be interested in a CD player mount that fits in the Heater control hole.
Can you PM me when you have something please.
Thanks.
Old 12-23-2008, 12:47 AM   #6
mekdad
mekdad's Avatar
Thanks.
Yep,the one I am working on will have a place for the ignition switch and cig lighter also and fill that whole area.If that is something you would be interested in?
Old 12-23-2008, 12:52 AM   #7
VA72C10
VA72C10
VA72C10's Avatar
I won't be doing that for my current truck, but in a year or two when i do my blazer w/ A/C I plan on doing just that. I am sure there are at least a few w/ aftermarket A/C that would want that.
Old 12-23-2008, 11:50 AM   #8
mekdad
mekdad's Avatar
I added a pic of the two hole one.
Old 12-23-2008, 01:44 PM   #9
Deuce
Deuce's Avatar
VERY Interested!!!
Old 12-25-2008, 08:43 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Also interested to see what you come up with for the lower piece w/ the ignition....is this set up for the 67 or larger ignition bezels or will it work w/ both?
Also, on this two/three gauge bezel, what would it look like if you left the metal on the edge (where you're taking the material off to make it flush? Just wondering if it might look good to fill the entire recessed area and stick out like the gauges next to it.
Old 03-27-2011, 09:58 PM   #11
Deenice21
Deenice21's Avatar
back from the dead. whatever happened to this? did you make them?
1971 LWB C10 - 5.3/350
1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet
1964 malibu ss - ls1/4l60
http://67-72chevytrucks.com/vboard/s...d.php?t=382403
Deenice21 is offline   Reply With Quote
