Old 12-22-2008, 08:47 PM   #1
daniel1
daniel1's Avatar
1" shackles
where are you guys getting 1" drop shackles all i see is 2" and i already have the flip kit just need the shackle for 7" also what brand shackle does the 1" thanks
daniel1 is offline   Reply With Quote
Old 12-22-2008, 08:50 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: 1" shackles
you could remove some leaf springs
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-22-2008, 09:14 PM   #3
f.monroe
f.monroe's Avatar
Re: 1" shackles
I am using my shackles or 1" of drop . Most shackles are 2" but have two holes in them . The top hole is the 2" drop . If you use the second hole , it should only give 1" of drop . If you are only looking for about one inch of drop but want to save a little money , go to a salvage yard and get some shackles from an 88 up chevy truck . They are a little longer than 73-87 shackles and will offer between 1/2" to 3/4" of drop .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 12-22-2008, 09:50 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 1" shackles
Remove the large heavy load spring. The drop is almost 1".
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-22-2008, 10:14 PM   #5
1984 swb chevy
1984 swb chevy's Avatar
Re: 1" shackles
If you rmove the heavy load spring will that hurt anything in the long run. I need around 1 inch also. Thanks
1984 swb chevy is offline   Reply With Quote
Old 12-22-2008, 10:25 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1" shackles
That spring is about 3/4" thick so it is good for a 3/4-1" drop. It is never used unless you put a load in the rear, then it kicks in when the spring pack sits on it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-22-2008, 11:37 PM   #7
gchemist
gchemist's Avatar
Re: 1" shackles
Not unless you load more than 500 lbs in the rear. I've run mine without the load spring since installing a drop kit. I've also added traction bars. I've carried a 455 Rocket engine without any problems. My truck actually runs better if I have some weight in the bed.
Old 12-23-2008, 12:03 AM   #8
daniel1
daniel1's Avatar
Re: 1" shackles
i have a flipkit so would i still get about an 1" from removing the load spring?
Old 12-23-2008, 12:07 AM   #9
flamingbig10
6.0 powered square
Re: 1" shackles
yes, and a better ride
Aaron
Old 12-23-2008, 12:12 AM   #10
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Re: 1" shackles
So if he has a flip kit ( axle on top of springs ) removing the 3/4" thick bottom spring will drop another inch?
I am going through similar motions with my Big 10. It has 7 springs per side, don't need some... Removing the thickest and adding a 2" drop shackle should gain me about 3" of lowering. I think...
bowtieguy79 is offline   Reply With Quote
Old 12-23-2008, 12:14 AM   #11
1984 swb chevy
Re: 1" shackles
with a flip kit isnt the load spring on the bottom of the spring pack and the rear on top of the springs.. I guess the spring pack settles some when you remove the load spring. Am I correct?
Old 12-23-2008, 12:23 AM   #12
flamingbig10
6.0 powered square
Re: 1" shackles
before I did a flip kit I had 2" drop shacles and 3 out who's know's how many and it gave me a just a little over a 3" drop in the back and a nice ride
same setup with a flipkit
there was no axle travel it might of been a better ride with shock extenders and a bigger notch
Aaron
