Old 12-22-2008, 10:21 PM   #1
knewman9n
knewman9n's Avatar
rear end width
Does anybody happen to know the width of a 72 chevy rear end and are the stepsides the same as fleetsides? Thanks.
knewman9n is offline   Reply With Quote
Old 12-23-2008, 12:19 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: rear end width
you didn't menton if it was a 10 or 20 series...
they are the same regardles of bed though
Old 12-23-2008, 09:44 AM   #3
knewman9n
knewman9n's Avatar
Re: rear end width
10 series.Thanks
Old 12-23-2008, 08:13 PM   #4
knewman9n
knewman9n's Avatar
Re: rear end width
Any body?
Old 12-23-2008, 09:58 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: rear end width
I believe the two different rear ends were based on years. Typically shown as 67-70 and 71-72. I can only give you the measurements from the inside of the brake backing plate mounting flanges, my '68 was 57" and the '72 was 58.5". Sorry I don't have the outside, drum to drum mount.
There is no difference if fleet or step side, just the year differences.
Hope that helps.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-23-2008, 10:22 PM   #6
68 short step
Re: rear end width
Originally Posted by chevy_mike View Post
I believe the two different rear ends were based on years. Typically shown as 67-70 and 71-72. I can only give you the measurements from the inside of the brake backing plate mounting flanges, my '68 was 67" and the '72 was 68.5". Sorry I don't have the outside, drum to drum mount.
Hope that helps.
68.5"??? inside of the backing plate to inside of backing plate on the 71 in my driveway and the 71 in my guarge its 58" (maybe 58.5", if i go end of axle flange to end of axle flange)....
68 short step is offline   Reply With Quote
Old 12-24-2008, 04:31 AM   #7
38chevyhotrod
38chevyhotrod's Avatar
Re: rear end width
I measured my 71 suburban yesterday.
I have 1626 mm from outside drum to outside drum, that would be 64 inches.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 12-24-2008, 11:37 AM   #8
chevy_mike
chevy_mike's Avatar
Re: rear end width
Doh!!! This is what happens when you get old. You suffer from CRS (Can't Remember $h!t). I was even thinking those numbers did not sound right but you are correct. 57" and 58.5". I corrected my above post. Thanks for the reality check.
