Old 12-22-2008, 10:38 PM   #1
mike14_07
mike14_07's Avatar
Muncie Swap????
I have a 68 swb i am restoring and i am going 2 swap to a muncie m21. I already have the trans and bellhousing. What else do i need to get and to do to make the muncie fit. My truck was an auto but i have manual truck to rob parts from that is going to become an auto.
mike14_07 is offline   Reply With Quote
Old 12-22-2008, 11:05 PM   #2
Gray Ghost
Gray Ghost's Avatar
Re: Muncie Swap????
Welcome to the board Mike. You're not too far from a good bunch of truck nuts. We are in Terrell...you'll have to cruise down sometime and check the gatherings out.
Do you have the clutch fork, clutch, throwout bearing, pedal, Z bar, shifter & crossmember yet?
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-22-2008, 11:11 PM   #3
mike14_07
mike14_07's Avatar
Unhappy Re: Muncie Swap????
i would love 2 as soon as i finish my truck
Old 12-22-2008, 11:28 PM   #4
chevy29267truck
Re: Muncie Swap????
welcome you also will need too find a high hump for the 4speed
chevy29267truck is offline   Reply With Quote
Old 12-22-2008, 11:34 PM   #5
mike14_07
mike14_07's Avatar
Re: Muncie Swap????
Not for a m21 its smaller than my th350. This is a car trans not a granny 4 speed
Old 12-22-2008, 11:49 PM   #6
chevy29267truck
Re: Muncie Swap????
oh ok
Old 12-23-2008, 01:54 AM   #7
Gray Ghost
Gray Ghost's Avatar
Re: Muncie Swap????
Right...my buddy has a panel truck that came with an M21. It is a close ratio tranny and he has the regular hump. The high hump is a wide ratio M20 iirc.
Kelly
Old 12-23-2008, 10:11 AM   #8
smoked68
smoked68's Avatar
Re: Muncie Swap????
I did the same, been in the ruck for about 5 years now. Mine was a 3 on a tree so all the linkage was there. Every thing should bolyt right up when you get all the parts mentioned. I uesed a car bellhousing the second time around. Alum. lighter than the truck steel. I also used a 1 pce. drv shaft but yours should hook right up if you want to go that route. I kept twisting Center supports. Good luck and if there is anything I can help you with gimme a shout. Good luck, Mike...
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 12-23-2008, 10:44 AM   #9
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Muncie Swap????
I've always wanted to put an M-21 in a 67-72.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-23-2008, 11:46 AM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Re: Muncie Swap????
I had one in my first truck (67 stepper). I used the three on the tree shifter for the four forward gears and a choke cable for reverse. It worked great if you didn't forget to put the shifter in neutral before pulling out the choke knob....
LockDoc
Leon
Old 12-23-2008, 01:25 PM   #11
smoked68
smoked68's Avatar
Re: Muncie Swap????
Huh, bet you never choked down in reverse either...
Old 12-23-2008, 03:07 PM   #12
c10addict
c10addict's Avatar
Re: Muncie Swap????
LockDoc
Nice!!! Have a m21 in mine, low hump...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
