Old 12-22-2008, 11:01 PM   #1
mike14_07
mike14_07's Avatar
A/c Controls delete
I am running a Mojave heater and don't want a big open hole in my dash any body got any ideas, pics please!
mike14_07 is offline   Reply With Quote
Old 12-23-2008, 12:16 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: A/c Controls delete
Check out Board Member: Mekdad
He has 3 posts with Custom Aluminum Pieces, Maybe he can make that Heater Control Delete for you (Below are links to his posts) Good Luck
http://67-72chevytrucks.com/vboard/s...d.php?t=320284
http://67-72chevytrucks.com/vboard/s...d.php?t=316255
http://67-72chevytrucks.com/vboard/s...d.php?t=316394
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-23-2008, 02:32 AM   #3
jeremy zander
jeremy zander's Avatar
I have pulled out all my radios and heaters in my trucks..Radio deletes work great in the heater space.Sorry no pics all my trucks are in storage for winter..mekdad made me a radio delete plate that would work to..JZ
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 12-23-2008, 10:08 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
1. Get a piece of 20-ga. sheet metal.
2. Make a template of the hole.
3. Transfer the image to the sheet metal with a no. 2 pencil.
4. Cut it out with a pair of metal shears/plasma cutter. Trim to fit.
5. Carefully weld it in. Grind down the welds, as needed.
6. Finish it, using a minimum amount of body filler.
This is the method that a friend would take in filling in a hole or creating a part. He's good.
Member Nr. 2770
