Old 12-23-2008, 02:47 PM   #1
HvyChevy
HvyChevy's Avatar
1 ton axle swap questions
My 1970 is finally going to get paint on it, so I'm getting my parts together so I can get to work on it when it gets home.
I have a Dana 60 and a 14BFF out of a 1986 Chevy 1 ton, flat bed, single wheel truck. The Dana 60 measures 32" from spring perch to spring perch. The 14BFF measures 40" from perch to perch.
The 14BFF is 54" from backing plate to backing plate. Is a disc brake kit going to go on this, and is it too narrow?
Anything I need to know, or get, to make these axles go in?
Thanks for any input,
Dan
HvyChevy is offline   Reply With Quote
Old 12-23-2008, 02:48 PM   #2
HvyChevy
HvyChevy's Avatar
Re: 1 ton axle swap questions
another angle..
I know there has to be some threads on this, just can't seem to find them
Old 12-23-2008, 02:59 PM   #3
desertrat
desertrat's Avatar
The disk brake conversion should not change youre wheel width.
The end product should end up being wider than youre stock 1/2 ton width.
You should come over to the 4x4 section. We don't get alot of traffic over there and youre post wont get lost so easy.
4x4 forum
Edit: I thought this post was in the 67-72truck thread, I didn't realize it was in the blazer thread.
I almost think the Blazer forum and 4x4 forum should be the same but that would eliminate the 2 wheel drive Blazer guys.
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 12-23-2008, 03:08 PM   #4
HvyChevy
HvyChevy's Avatar
4x4 forum
Ok, I did.
thanks
Old 12-23-2008, 05:53 PM   #5
vtblazer
vtblazer's Avatar
Direct bolt in for both.
Doing the same with mine currently.
vtblazer is offline   Reply With Quote
Old 12-23-2008, 05:55 PM   #6
HvyChevy
HvyChevy's Avatar
Thanks vtblazer! I was just reading your thread. I've still got a little time, so I'll just keep watching your progress. Nice work BTW !!
Old 12-23-2008, 06:07 PM   #7
vtblazer
vtblazer's Avatar
Thanks,
Welcome to the board, enjoy the ride.
I have the same axles as you do, tons from an 86 CUCV.
Look em over good, mine were worked hard and put away wet.
Old 12-23-2008, 08:14 PM   #8
HvyChevy
HvyChevy's Avatar
Originally Posted by vtblazer View Post
Thanks,
Thanks! Can't wait to start working on it again. It's been in my brother in-law's body shop for (seems like a year).
I guess my next step is to get them cleaned up and start ordering some brake parts. The glove box tag says code GT5 rear axle 4.10 ratio
(I love all the info from this board!!!)
Old 12-24-2008, 12:24 AM   #9
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Don't forget about the rear shock mounts, both have to be relocated. Other than that they are both a direct bolt in.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
