Old 12-03-2002, 08:45 AM   #1
moose326
5 Speed Stick In 4x4?
SEEING AS HOW MY TH350 IN MY 69 K10 HAS LET ME DOWN, I AM THINKING OF PUTTING A 5 SPEED MANUAL IN IT. PROBLEM IS IM NOT SURE WHAT TO LOOK FOR. I KNOW THAT I DONT WANT AN AUTO ANYMORE. IT WAS A 4SPEED WITH A ROCKWELL BEHIND IT. BUT IT WENT TO HELL. I HAVE 410 GEARS IN IT AND DONT LIKE REVING THE PISS OUT OF IT AT 60 MPH. I DONT DRIVE THIS TRUCK HARD. JUST THE OCCASIONAL HUNTING TRIP IN THE FALL. ANYONE GOT ANY IDEAS? AND I WILL APPRECIATE ANY INFO. AND I DONT WANT THE NP203 IN IT EITHER!
moose326 is offline   Reply With Quote
Old 12-03-2002, 10:12 AM   #2
Mike C
Mike C's Avatar
WHY ARE YOU SHOUTING? GM offered the NV4500 and a Getrag 5 speed in later model trucks. You can get an adapter for the NP205 t-case to the NV4500. Be forewarned, the tranny is about $2000 used and the adapters is close to $1000. Check out www.advanceadapters.com Just getting rid of the slush box will drop RPM by at least 10% due to converter slippage. Another option is taller tires. I have 4.10 in my Jimmy with 35" BFG MTs and it turns 2600 at 65 mph. Still not economy range, but not so bad.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-03-2002, 07:12 PM   #3
nu2-72
I currently have the 4-spd and 4.10 gears. I was looking at the NV4500 also but to be honest, I think the cost and effort to convert will be too much.
This truck seems to have way too much at the low (granny) end and not near enough at the top.
I have since decided to change gears to 3.73. Since I never use the 1st gear, I basically have a three speed. By changing gears I hope to save money, (parts), use stock original parts and add a small lift with bigger tires. This should gain the most for the money. And I will still have the low 1st if I need it.
Also the speedometer will still work. The later 5-spds are electronic and expensive to adapt.
Hope this helps.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 12-03-2002, 09:08 PM   #4
8mag
i had the nv4500 in my truck and it was okay. had all new bearings put in it and it still howled. sold the whole mess and am in th process of getting a gear vendors overdrive. the idea of splitting gears especially while towing seems like the best way. 3 gear now to low for some hills but a 3rd high should be about right .
1972 3/4 4x4,14bolt locker rear, dana44 lock right front, sm465, sb 400, blazer tank,dual batterys,3"lift,32-9.00-16 super swampers
daily driver
other trucks
1972 1 ton dually 4x4,454 4 spd,,235-85-16, flat bed front and rear winches, rear gas tank and under bed gun safe.tilt wheel
8mag is offline   Reply With Quote
Old 12-05-2002, 09:50 AM   #5
Mike C
Mike C's Avatar
The gears are a good idea, but the gear vendors is not an option in a lifted 104" wb Blazer/Jimmy. The driveshaft is already too short! Best thing I did was going to a smaller cam. , 230 @ .050 always had the motor OUT of the peak torque range after a shift. If you can increase your average torque between 2000 and 4000 rpm you can take advantage of the gear spacing on the SM465. Peak power should be 4-4.5k rpm. Try a cam with max 210 @ .050 duration. I am running a 331, but a 355 or 383 with same cam should be perfect with a final drive effective ratio in the 3.30 to 3.70 range. (My 4.10s with 35" tires are effectively the same as 3.40s with a 28" tire.)
44 Willys MB
52 M38A1
64 Corvette Coupe
