just got a new truck
me and my dad just bought a 78 chevy two door short bed truck for fifty bucks trucks nice but no motor or trans i will take pictures of it and post them when i get back but i want to know whats the best way to get the most travel out of it for jumping or off road racing i do know i want to do the fenders front and rear also full cage bumpers front and rear but also a nice daily DD if anyone has pictures of a completed truck or any ideas how to do it it would really be appriciated
LIFTED OR LOWERED EITHER WAY STOCK SUCKS 75 Chevy blazer 86 trx 250R 1990 Ford Ranger 2wd prerunner project |
2WD 4 Life
Re: just got a new truck
sounds like a tall order man. good luck
Big D 1969 c10 1960 cadillac 1978 king cobra |
ya just a project truck somethin to do after school to keep me out of trouble
![]() Join Date: Apr 2004
jumping your truck and off road racing don't usually pair well with a daily driver. you are going to need to decide whats more important.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
I agree with hotrodhomi...jumping+offroad racing do not = daily driver. I would think it's going to have to be one or the other.
1961 GMC 930- SOLD 1979 GMC C35 Single Wheel Camper Special- SOLD 1980 GMC C25 Camper Special- SOLD 1983 Chevrolet C10- SOLD 1983 Chevrolet Camaro- SOLD 1985 GMC C1500 (Dad's truck) 1985 GMC C3500 Crew Cab Dually- TRADED FOR 61 GMC 1997 Dodge Ram 1500 V6 Shortbox- Daily Driver ![]() |
Is it a 4wd or 2wd?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
KOOL SCORE BUD. GOOD LUCK WITH IT. HEY CAN U POST SUM PICS OF THE BLAZER IN UR AVATOR? GOOD LUCK WITH THE TRUCK
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
2wd and no serious jumping but something that can handle minor off road trips to the desert maybe the sand dunes and just so more of a dd than a race truck
You need some custom tubular A arms for the front. --- widening the track width at the same time will help as well.
Are you retired too? Nonsense! I'm in my prime |
For good/real offroad/desert ability you will need widened control arms as already mentioned by streetstar.. and coil over shocks instead of coil springs. You would need to remove the spring cup..
The stock set up does not allow a good range of motion especially if the suspension is lifted at all. The upper control arm bottoms out on the upper coil bucket not allowing much droop in the suspension, which is needed for a properly tuned suspension.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 12-27-2008 at 05:37 PM. |
do you know a good site that would sell the wider a arms i am thinkin about four linking the rear for sure and fox or king shocks all the way around hopeing to get about 17 inches of travel at each tire if possible but if i could at least get 10 that would be good for me
LIFTED OR LOWERED EITHER WAY STOCK SUCKS 75 Chevy blazer 86 trx 250R 1990 Ford Ranger 2wd prerunner project Last edited by lifted 75 k5; 12-25-2008 at 04:37 PM. |
Sb 400 club
A member on here named Prerunner had a lifted 2wd.
sounds like a cool project/
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#13 |
It'd be alot cooler if you did
Step one:
Throw all the stock suspension in the garbage. step two: read, make contacts, and look at other trucks that you know can do what you want to achieve. Step three: Build a new frame or at the bare minimum box the stock one from front to rear. step four: Build the suspension around the coil overs, and remember the higher up you put the upper mount the better it is going to handle. |
#14 |
i have been reading doing research taakin to my dad and i think i have decided to just lower it and put it on bags because the family theory is 4wd put them in the air 2wd drop them to the ground so i think i will stick to that
#15 |
That will require less custom work since that mod is more common than making a baja truck out this body style. Good Luck
#16 |
here is the picture of my truck in my avatar
