Old 12-03-2002, 08:50 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Smile Woo-Hoo!! I got my brake lights working!
I just replaced my turn signal switch and now the brake lights are brighter than ever!. I haven't driven the truck much lately because I had no brake lights and the battery has been draining. Even my turn signals and arrows in the dash seem brighter. The switch and harness was $28 at the dealer. Easy job to do. I saw alot of posts on here about this and refused to believe the switch was bad because it looked fine. Also rewired my aftermarket volt gauge correctly to prevent the 80 milli-amp drain I was having. Life is good again!....Now when I get my front and rear light harnesses from fellow board member Wornbrakes, I'll be set.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
