Old 12-23-2008, 08:15 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
stacks
ive bean thinking about putting stacks on my truck and i was wondering do you guys think it will look good and also do you know where i could get a cheep kit
pokethesmot is offline   Reply With Quote
Old 12-23-2008, 10:15 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: stacks
I almost put a set on my old fleet F*** 30+ years ago but didn't.
IMO, 4/6" diameter stacks inside the bed hooked to a BIG nasty diesel looks better.
Get a side shot of your truck and a pic of some stacks and ask the photoshop guy's to put them on, Then you can see how it would look.
But,
If you look like either of these guy's then just slap um on an call it a day....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-23-2008, 10:17 PM   #3
joe231
joe231's Avatar
Re: stacks
CHEVY ONLY
Old 12-24-2008, 10:16 AM   #4
Prerunner1982
Prerunner1982's Avatar
Re: stacks
I have a stack I am saving for my 4x4 project..... though at this rate I will be holding on to it for awhile...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-24-2008, 10:26 AM   #5
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: stacks
I think they belong on the Lil' Red Express disco Dodge only!
crawdadfox is offline   Reply With Quote
Old 12-24-2008, 10:35 AM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: stacks
but, yeah.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-24-2008, 11:25 AM   #7
seanconnery
Re: stacks
I think stacks are pointless on any truck, unless its an 18-wheeler. I'm no exhaust expert, but isn't there a mathematical relationship between the diameter of the exhaust and the output of the motor that it's hooked to? Doesn't the motor actually lose power if the exhaust is too big? It has to do with compression too, doesn't it? That's why the rigs use them, cause the diesels compression ratio is so high that the cycle forces the exhaust out much more severely that it actually needs the extra large diameter, right?
G to the M to the C......fool!
RIP Jerry Reed "The Snowman"
seanconnery is offline   Reply With Quote
Old 12-24-2008, 11:34 AM   #8
pokethesmot
Re: stacks
you can get thinner exhaust tubing it comes in all sizes
Old 12-24-2008, 12:11 PM   #9
Prerunner1982
Re: stacks
You could run regular 2.5" exhaust up the inside of the stack until about last 12" or so.. it would work like a big echo tip..
In the 4x4 world they increase the fording depth of the vehicle. Of course a snorkel and water proof electronics would also need to be included in that..
Jon
Oklahoma Roll Call
Old 12-24-2008, 12:30 PM   #10
bigblock73
yeller
bigblock73's Avatar
Re: stacks
Unless they are horizontal and on a mid 60's Vette!
bigblock73 is offline   Reply With Quote
Old 12-24-2008, 12:40 PM   #11
seanconnery
Re: stacks
Those are good points that I never thought of. What you see on the outside wouldn't necessarily be the true diameter of the pipe.
Old 12-24-2008, 12:43 PM   #12
Prerunner1982
Re: stacks
Or on a Gremlin..
Jon
Oklahoma Roll Call
Old 12-24-2008, 12:47 PM   #13
Prerunner1982
Re: stacks
You were right on the money though. I wouldnt run Dual 4-5" stacks on a small block gasser.. Now a single stack wouldnt be too bad which is all I plan to run.
Jon
Oklahoma Roll Call
Old 12-24-2008, 12:50 PM   #14
bigblock73
yeller
bigblock73's Avatar
Re: stacks
Originally Posted by Prerunner1982 View Post
Or on a Gremlin..
I would roll that Gremlin all day...but would have to lose the pipes before I hopped in.
Early Gremlins are cool IMO.
Old 12-24-2008, 02:15 PM   #15
piecesparts
Parts and more parts
piecesparts's Avatar
Re: stacks
A good design for an exhaust system will work to help eliminate exhaust gases from each cylinder. This design should look at the collapse of the gases as a way to create a vacuum to pull the gases that are following them. The size of the exhaust piping is important to get this reversionary pressure out of the way, thus making the engine develop more power. The bigger piping will not help unless it is SO big that it provides no restriction.
Stacks on a pickup look so tacky in my book----unless that truck has a some seriously large engine (like a diesel).
piecesparts is offline   Reply With Quote
Old 12-24-2008, 02:32 PM   #16
pokethesmot
Re: stacks
for every one hating on my truck for not being a diesel if it makes you guys feel better...my truck was a diesel but the previous owner switched out engines heck my gauge cluster still says "diesel fuel only" lol
Old 12-24-2008, 02:50 PM   #17
chevymotocross
chevymotocross's Avatar
Re: stacks
Both my buddies have k20 trucks. Lifts, big tires, fresh paintjobs, built small blocks. They both installed dual stacks. One of my buddies powder coated his pipes black, the other are stainless steel. I will have to grab some pics. I will admit, when it is done correctly, they sound and look good. They are very loud, and since they are pointing up, they echo off of everything. Sometimes I hear there truck a great distance down the road, thinking it is a straight piped harley. Totally different sound then a truck with normal ran dual exhaust system.
chevymotocross is offline   Reply With Quote
Old 12-24-2008, 03:27 PM   #18
thump16
thump16's Avatar
Re: stacks
There was a guy at the swapmeet selling his 82 GMC shortbed big block with diesel stacks under the bed as his exhaust.
thump16 is offline   Reply With Quote
Old 12-24-2008, 05:30 PM   #19
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: stacks
Hell at first I thought he was talking about VELOCITY STACKS on the intake!!!! YEP STICK THEM SUCKERS RIITE UP DER TRU DAT HOOD !!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-24-2008, 05:34 PM   #20
Square84
I don't think these pills work
Square84's Avatar
Re: stacks
Or on a Gremlin..
i know its a chop but this thing is bad ass
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 12-24-2008, 07:49 PM   #21
WarBeard
WarBeard's Avatar
Re: stacks
I dig the stacks
Here is my dodge it had a big whopping 3.7l v6...i ran a single stack loved it.
some people loved it and some hated it but who cares!
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 12-24-2008, 10:22 PM   #22
87Bob
Re: stacks
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 12-24-2008, 10:51 PM   #23
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: stacks
One of the first square bodies I remember from my childhood was a friend a couple years older than me who got a mid 70s stepside and had stacks going through the steps. Not personally a look that does much for me, but I'm a big believer in building your truck to suit your tastes.
There's another guy on here who has stacks on a 2wd stepside, but I can't remember his name right now. I'll see if I can find the username and a pic...
-- Will
killthewabbit is offline   Reply With Quote
Old 12-25-2008, 12:04 AM   #24
bigblazerboy
bigblazerboy's Avatar
Re: stacks
like this
bigblazerboy is offline   Reply With Quote
Old 12-25-2008, 12:14 AM   #25
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
Re: stacks
that vette is sick!
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
