Old 12-23-2008, 11:01 PM   #1
blakeaz33
blakeaz33's Avatar
Upper control arm hardware
Anyone ever removed and replaced the 2 pressed in upper control arm studs? I am replacing the crossmember in my 68 with a 73-87 style and the studs are in bad shape and need replaced - to rough to clean up. I've not had any luck locating replacement hardware online with several searches. Any help would be greatly appreciated.
blakeaz33 is offline   Reply With Quote
Old 12-24-2008, 12:50 AM   #2
blakeaz33
blakeaz33's Avatar
Re: Upper control arm hardware
These control arm studs look like a 1/2" x 3" wheel studs - if I don't have any other luck I'll try these.
Old 12-24-2008, 09:50 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
LMC truck carries them and probably a few other places. You can also get longer studs from ARP that will fit, but I don't have a part number...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-24-2008, 10:37 AM   #4
blakeaz33
blakeaz33's Avatar
Thanks GRINGO - found it.
http://www.lmctruck.com/pdfcatalogs/pdf/cc/CC20.pdf
