Old 12-24-2008, 10:02 AM   #1
Wootdog
Wootdog's Avatar
Steering Wheel column cover removal question
I have a dent in my column cover. The round thing where the turn signal and tilt lever go into. I need to remove the collar to fix the same. Any one know how to get it off? I have a private message into Kev's classics but he must be gone for the holidays. I have the steering wheel and everything else removed below it but the cover around the column.
Thanks,
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 12-24-2008, 10:22 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Steering Wheel column cover removal question
It is just slid on over the inside like a skin. It should just slip off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-24-2008, 10:30 AM   #3
Wootdog
Wootdog's Avatar
I am trying to remove it from the top so I don't have to remove the whole column.
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-24-2008, 10:32 AM   #4
Andy4639
Old member
Andy4639's Avatar
I don't think that you can do that. I'm not certain, maybe some one else knows for sure. Mine was out of the truck.
Old 12-24-2008, 10:43 AM   #5
JimKshortstep4x4
Is your column a tilt or standard?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-24-2008, 10:47 AM   #6
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Thanks,
Kerry
These are some pictures of my non tilt unit. You will need to remove the turn signals three screws to remove it. I have lots of pictures if you need anything.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-24-2008, 10:49 AM   #7
Retro68
Look very close around the seam. You will see a small indent. Use a very small round flat end punch and tap lightly forward. You should see the seam open a little. If it does work your way around the seam in small amounts . You should see the collar moving and sliding off. Be gentle so you don't dent the edge. If the column has had some repaint the paint may act as a seal at the seam. If so go around the seam first with a razor blade to break the paint seal. Any further questions let me know.
Retro68 is offline   Reply With Quote
Old 12-24-2008, 10:58 AM   #8
Sport/Truck
Sierra Grande Club
It must be different on a non tilt. So my pictures won't be much help.
s/t
Old 12-24-2008, 02:22 PM   #9
Wootdog
Wootdog's Avatar
I have a tilt column.
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-24-2008, 03:22 PM   #10
john
member #16
john's Avatar
With a tilt it will just tap off. I use something soft in the turnsignal lever hole to move it.
john is offline   Reply With Quote
Old 12-24-2008, 03:34 PM   #11
Wootdog
Wootdog's Avatar
This is removing from the top correct? the tilt column is installed on the truck.
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-24-2008, 09:02 PM   #12
JimKshortstep4x4
The cover is held on by a slight interference fit. If you spray the parting line with a penetrant it will help the removal of the cover. The cover comes off toward you. The manual recommends using an inside puller but I use a small flat screw driver and gently tap the cover off with the screwdriver tip agains the bottom edge. The cover has to be "worked" off by going around it if you choose to use a screw driver to remove it.
Of course the levers have to be out of the way and remove the flasher button after depressing the switch.
Jim
Old 12-25-2008, 01:25 PM   #13
Wootdog
Wootdog's Avatar
Well guys. I give up. Nothing you have suggested appears to work. All I have seemed to do is scratch the paint off in multiple areas between the top collar and the bottom one. I guess I will have to live with the dent. And to add insult to injury, it appears I have cracked the lower collar.
Thanks anyway
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-26-2008, 05:07 AM   #14
JimKshortstep4x4
Wow!
That is a bummer!
Here is a pic of how the manual suggests removing the turn signal cover.
Jim
Old 12-26-2008, 09:39 AM   #15
Wootdog
Wootdog's Avatar
Is the bolt on the steering shaft supposed to be removed? I can't see it in the picture. If that's the case, that is why I can't get the collar off. I actually tried to get a socket on it as well as a wrench and can't get it to move.
Thanks,
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-26-2008, 09:03 PM   #16
JimKshortstep4x4
The nut on the shaft does not have to be removed. The cover is just a tight fit on the housing.
Jim
Old 12-30-2008, 11:22 AM   #17
Wootdog
Wootdog's Avatar
Update. I ended up buying a K and D Part number 2291 Steering Wheel Puller and Crankshaft Pulley Puller. I also had to buy a K and D Part Number 3510 GM steering Wheel Puller Legs. The legs fit into the Steering wheel puller Main bracket. It was not cheap. It took longer to go get the parts for the collar removal than it took to remove it. Thanks you guys for all your help.
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 12-31-2008, 10:24 AM   #18
Sport/Truck
Sierra Grande Club
Kerry
Was there anything preventing yours from coming off? I'm curious why it wouldn't slip off.
s/t
Old 12-31-2008, 12:49 PM   #19
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Good info
LOW DOUGH is offline   Reply With Quote
Old 01-01-2009, 07:31 AM   #20
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
s/t
The Tilt Steering Wheel column cover is pretty hard to get off if you don't have the propper tool. I had to take mine to Vintage Chevy here in Fremont to have it removed after trying for days myself and breaking the Horn contact switch.. and when you put it back together you have to line up the little indent thingAmagiga...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 01-01-2009, 10:51 AM   #21
ashx2
I'm curious, since I have to do the same thing to mine. I have to put in a new blinker setup since the one on mine is busted.
I read in the manual that you are to depress the hazard knob inward and unscrew. When I tried this however, it cracked the knob. So how did you remove yours? Did you have to depress the hazard knob or did you just manuver it around?
Please tell me you tooks pics of the dis-assembly and your puller you had to buy.
Greg
ashx2 is offline   Reply With Quote
Old 01-01-2009, 10:51 AM   #22
Wootdog
Wootdog's Avatar
The reason it would not just slip off was because of the big dent in it.
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 02-12-2009, 02:39 PM   #23
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Thanks,
Kerry
Kerry, So sorry UPS was so careless with your tilt. I sent you another cover should be getting it any day. Just send me your dented one back when you receive it.
Thanks, Kevin
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
