![]() Join Date: Dec 2008
Question on 4 wheel lift
Does anyone know on my 72 4 Wheel drive how much of a body lift can i put under it without having to lengthen stuff and can i use a 2 wheel drive cab thanks for the info tony
10/30/19
Re: Question on 4 wheel lift
Yes you can use your cab..they are all the same..as far as the lift question,I don't know..I will let someone else chime in.
Fight the good fight, finish the race, keep the faith |
![]() Join Date: Nov 2003
Your two wheel drive may have a low hump, but you could cut that out and put the high hump in it very easily. Of course, if you are running a body lift you probably won't need a high hump cab anyway.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
i am using a body lift just not sure how high i can go before having to lengthen stuff and my 4 wheel cab has the high hump and the two wheel cab im using has the low thanks for the info
I would avoid the body lift and go for add-a-leafs and zero rate leafs if you want a cheap lift.... too many things to modify and I think they are ugly... my 2 cents
You have to cut your fan shroud, modify firewall for steering column, brake lines, clutch linkage, bumper brackets....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
ok thanks for the info
