12-24-2008, 02:27 PM | #1 |
Help with Wiring for Temp Guage
I just purchased a bezel and guages from 72armyswbtruck.
My problem is, the previous owner put in an aftermarket temp guage with that heavy duty wire going into the engine block. Can anyone tell me how to convert my temp sending unit back to one that works with the original guages? Hopefully Im explaining myself..... thanks for any help. Travis |
12-24-2008, 09:06 PM | #2 |
Re: Help with Wiring for Temp Guage
Do you have the gage wiring harness or do you have to make up the wires?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
12-25-2008, 04:23 PM | #3 |
I have the original harness to all the guages....except the temp guage. it was replaced by an aftermarket one.
12-25-2008, 04:29 PM | #4 |
Sounds like the heavy wire you are talking about is actually a mechanical gage if so you will have to replace it with a temp sending unit and run a wire from it to your new gage.
69 Chevy 4x4 383 Power |
12-25-2008, 06:46 PM | #5 |
Active Member
Ditto - the original gauge would be a mechanical one - you should be able to pick up a new sending unit and capillary tube from a local auto parts store.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
12-26-2008, 11:32 AM | #6 |
Great! Thanks guys, thats what I needed to know!
Thank you, Travis |
