Always on the hunt...
![]() Join Date: Sep 2006
FS: TH400 W/BBC Auto Trans Shift Linkage - OR.
BBC-Th400 shift linkage removed from a 71 C/10 factory 402 big block truck, this setup (circled in blue) includes the longer main rod with slight bend and the bbc only frame pivot, these parts were used due to the motor/trans position on the bbc's. $50... payment by US postal mo or pp/cc, will ship at buyers expense.
Re: FS: TH400 W/BBC Auto Trans Shift Linkage - OR.
what about ps parts shown in pic,are they for sale?
ttt
Resident Curmudgeon
![]() Join Date: Dec 1999
Mel, I'll take it.
jeff
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Under Construction
I have a parts truck that was a 402/400 and i was going to use the linkage on the '67 for a 350/350 combo. From what i am reading will this only work on a bbc?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Resident Curmudgeon
Ship to Zips:
UPS/FedX, etc --> Business address 03223 US Mail --> 03580 TTT. Thanks. PM me with total.
#7 | |
Member #1049
If you dont mind drilling holes and lining in up you can make it work.. the factory Big block sits in a different location than a small block. does your linkage look like the one pictured? Last edited by Livrat; 12-27-2008 at 03:07 PM. |
Under Construction
Mel,
Sorry for threadjacking! Livrat, The linkage i have is pictured below. I dont mind drilling holes, but i was hoping the '67 frame had the holes drilled already and that i could just bolt the linkage to the frame, and hook up to the column.
Resident Curmudgeon
TTT, Mel must be AWOL on Holiday.
Those pictured big block p/s parts have been sold, but I do have a few other complete big block trucks I could pull a setup off of. The price for a BBC short w.p. only p/s setup would be $300. and would include the remote res./pump, pump pulley and both pump mounting brackets.
#11 | |
I am interested in a set, If you still have more than one.
Please let me know. Thanks! BBB Last edited by BigBlockBurris; 01-01-2009 at 09:23 AM. |
#13 |
#14 |
I'll take the remaining one! Thanks!
PM Sent BBB |
#15 |
Do you still have the BB Trans Shift linkage setup or maybe another you would sell?
2-15-2010 Mark Booher 214-926-0119 cell BooherPerformance@earthlink.net |
