Nothing to see here.....
![]() Join Date: Jun 2007
just wondered about doing it to get a little more front end travel, then install a small urethane hockey puck bump stop.
anyone pulled this off with good results?? Thanks!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Too many projects
Re: Anyone shave the metal bump stop tower off the bottom A arm??
I have removed it to lay frame with air bags, just drill out the spot welds through the bump stop and pound off with a chisel and hammer.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
67-72 parts collector,…
![]() Join Date: Nov 2002
I always do this mod. (including using the small "energy Suspension" bumpstops)
Alot of people remove the entire bracket,... but I like to trim off the bumpstop bracket portion only,...and leave the steering stop.
i threw a sawzall in the hole there and sliced it off. helped greatly with 2 inch drop springs and 2.5 inch spindles.now i don't have any bumpstop but i don't think i've bottomed out in the front.
VA72C10
![]() Join Date: Mar 2008
Any pics?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
