need bearing/spindle help !
a year ago i had bought a complete disc brake comversion kit off ebay. it had 2 1/2 dropped spindles and 1 1/4 drilled rotors and it included the 73-87 ball joints to make it work on my 70. i have decided to raise it back up to stock, so i went to the junk yard and got a pair of stock spindles off an 83 1/2 ton. today i started to switch them out and they bolted up to the ball joints and tie rod just fine. but the rotors won't go back on ! did some checking and the bearings are bigger i.d.on the drop spindles. what do i need to change to make this work ? i would hate to have to buy new rotors ? any ideas ?
70 c10 stepside ,350v8, m-20 4 speed ![]() |
#2 | |
Re: need bearing/spindle help !
69 Chevy 4x4 383 Power ![]() |
i'm wondering if the 1" rotors have a differant bearings ?
Hollister Road Co.
The outer is the same on both - BCA A3, You need an BCA A5 set for the 83 inner, also get a BCA 8871 seal. Replace the cup and the bearing and you'll be ok. The 1" rotors are A3 outer and A6 inner. A6 is a smaller ID bearing and a shorter cup.
well i just went and bought the a5 bearings and they are way to sloppy for the spindles. i'll take them back and see if the a3 bearings will work. i hope i can keep my 1 1/4 rotors.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Sounds like you purchased some light duty spindles off of the junk yard truck. It probably has 1" spindle pins and if so the 1 1/4" rotors will not work on them. You need spindles with 1 1/4" pins. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
yep your right. i called the place that made the spindles. they said every thing is differant between light duty and heavy duty,(1" vs 1 1/4").including the calipers,bearings.rotors...so i went back to the junk yard and found a 79 with 1 1/4 rotors,so i grabed the spindles and slid my bearing over it to make sure. now i'm back in bussiness. it was also a lot cheaper than buying everything for the 1" spindles.
