12-25-2008, 08:37 PM | #1 |
help needed on shoulder belts
As most of you know, shoulder belts for these trucks are more rare than the ultra rare 3 door burb.
Since shoulder belts are basically additional sets of belts, just bolted to the pillar,what other vehicles of the same era have the upper cab hardware that would make a set of belts? Anything out there? My truck needs blue belts but I have only seen black shoulder belt covers. Were there other colors? If so, were they all black and dyed like dash pads? Any help on this is greatly appreciated.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
12-25-2008, 11:56 PM | #2 |
Re: help needed on shoulder belts
I have not seen any factory blue shoulder belts, but my 71 has factory black belts, I sold leddzepp a set of factory red belts and just traded for a set of teal belts, so blue was an option and are out there somewhere. The upper boots are different animals from car units used during the same era, and you can id a set of non original belts because of the boot. Stock has a recessed retainer molded into the plastic/rubber of the boot. All of the repops I have seen have no retainer built into them and are thinner material. Cheyenne Super-man offers rewebbed belts with repop covers on them for $195 in any color, which is not a bad deal considering most don't know what the originals look like anyway. There is also a label (if still present) located at the bottom near the buckle that states "not for use with anyone under 4'-7" tall".
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-26-2008, 12:06 AM | #3 |
12-26-2008, 09:56 AM | #4 |
hdflstf, are they just like 72 period or are they later model that work in place of originals? I want the correct belts if possible. Even if I have to buy several sets to make one complete and dye them.
12-26-2008, 10:39 AM | #5 |
Old Skool Club
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-26-2008, 11:18 AM | #6 |
Born Psycho
i believe black is most common(if common is the proper term,lol) but they were available in other colors. my cousin has a set of blue ones out of a 68 suburban, i used to have a set of brown/saddle? out of a cab i found that was headed to the scrap yard. i have also seen them in red. i don't remember what year, but corvette uses the same upper rubber piece. i built a set out of a NOS vette set i bought years ago, the vette buckle is different so i cut up a set of pickup seatbelts and had an upholstery shop sew them up using a set of original truck belts as a pattern. i'm sure the vette belts would be worth a fortune now.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-26-2008, 07:22 PM | #7 |
My belts came out of a mid-80s Suburban, and are gray. They probably had blue too.
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
12-26-2008, 07:45 PM | #8 |
MXmaniac, please, I do not want 80's, I want original if possible and I have been waiting several years so what is a little longer.
Jerry, I will check on Vette stuff. Thanks. And Julianos is the same late model stuff. 72-72-72 How do the restoration experts do this??
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide Last edited by nu2-72; 12-26-2008 at 07:49 PM. |
12-27-2008, 08:16 AM | #9 |
The belts were available in any color.It was just so rare to order the option.Black is the most common interior,so...
Alot of Suburban ambulances got them.I guess fire departments were more safety conscience for some strange reason,go figure(that`s a joke,son).Since most were red or white from the factory,red was most common and white ones could have had blue.Either could have had black interiors,too.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-27-2008 at 05:48 PM. |
12-27-2008, 12:18 PM | #10 |
I'm not really familiar with factory belt though I would say the are not 'original'.
12-27-2008, 07:13 PM | #11 |
SWB 4x4 Collector
nu2-72 - I used the middle seatbelts out of a 1969-1972 caprice. They look very close to the original belts when I put them in. The only difference is that they are a darker blue, which don't look bad, but I will eventually get a set of the factory blue or make my own. You can buy the correct boots from a corvette place, but they don't have the recessed square hole the securely holds the belt upright when not in use. Believe me when I say it, you definitely want to have that recessed square to hold that belt in. With my set, those belts get to blowin' in the wind with the windows down. Here is a pic of the setup I had before my recent tear down.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
12-27-2008, 07:21 PM | #12 |
SWB 4x4 Collector
Oh, and the cover I used was a cut down seat belt cover out of a dodge van. After looking at the pics though, I kinda like the darker belts. I am going to buy a set of reproduction covers from a vette because they are the same, but I am going to make a metal stamp for them to heat up and emboss them and make the seatbelt hanger. Here is a pic of original and the second is the repro.
71 super - can you please take some measurements for me on the correct size square that is punched into your factory covers??? I am trying to get it exact and not many have them. Thanks Trevor
12-28-2008, 07:51 PM | #13 |
Trevor, the picture of the red covers you have is correct. The blue ones in the picture of your truck (vette) are too long to be correct. You are correct in that the recessed portion is necessary to retain the belt. I can take pictures for you wednesday. Please send me your email and I will send them to you. Harold
12-28-2008, 08:22 PM | #14 |
Hey Trevor,
let me know how the emboss process goes, I have a set of black boots that I have been thinking about doing the same thing to. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
12-29-2008, 03:11 AM | #15 |
SWB 4x4 Collector
Hey Jeff, I will post pics of them when I get them done. I might just have to perfect the method on my old seat belt boots first but I should be able to get them looking good.
Edited by Mod.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever Last edited by Richard8971; 12-30-2008 at 12:21 AM. Reason: Trade offered by non-supporting member |
12-29-2008, 01:39 PM | #16 |
Moderator
Here is a set of covers that sold on Ebay....they were advertised as from a 67-72 Chevy truck. Look at how they are different from the other pics...
12-29-2008, 03:06 PM | #17 |
SWB 4x4 Collector
ledzepp- I have never seen those before. Everyone I have ever seen are like the red ones I pictured. Trevor
12-29-2008, 04:21 PM | #18 |
Those on ebay are WRONG, the red set is correct for trucks. The vette covers are smooth and do not have the dimple in them as trucks do. I have no idea what the ebay units came from, a van maybe. The vette covers are the common replacement for originals, and to my knowledge no one repops a correct set for the trucks, but the covers are also a dead give away for unoriginal set.
12-30-2008, 12:08 AM | #19 |
The ones that sold on Ebay are for a late 60's Mercury Couger or some other Ford from that time peroid. I bought a set of those about a year ago and they were advertised on Ebay as ford (or Couger, I can't remember) belts, I think I gave around $20 for the boots with belts. I dyed them blue and have them in my truck now. They are similar but not original to our trucks. Whoever sold those misrepresented them. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. Last edited by chipflyer; 12-30-2008 at 12:10 AM. |
12-30-2008, 07:56 PM | #20 |
OK, we have decided that the black set on 71blksuper4x4 post are repop.
But no one has said by who or where. Can someone give a vendor, part #, price or any info. Thanks.
12-30-2008, 11:20 PM | #21 |
Try CS-m. Gary can get you a new set of the vette covers, as they are what he uses on the reproduction shoulder belt sets he sells. Unless he has gone up you can purchase the boots, new belts with buckles etc. ready to install in any color for $195 and shipping. Check out his web site and give him a call, he is a very nice man and a pleasure to talk to. I have given him alot of money between two trucks over the years.
12-30-2008, 11:55 PM | #22 |
SWB 4X4 CLUB
Take a look at the following ebay links.
200260076561 200260075567 200259753988 The ones in the auctions are close but donot have the indentation to clip the belt into when not in use. I can get some pictures of them next to an original set tomorrow if interested. (The ones on ebay are not mine but I have some that are similar) Jason |
12-31-2008, 05:14 AM | #23 |
I to e-mail Gary last week and it would not go through. I will call him today. Thanks guys.
I also co-own a machine shop so the indent tool should not be a problem to make.
