Old 12-26-2008, 04:29 PM   #1
bighead
12 Bolt Drag Rear
12 bolt coil spring housing that was cleaned up, axle tubes welded, and repainted black. Moser 33 spline alloy axle kit with c-clip eliminators, 1/2" studs, Mark Williams billet cap, solid pinion spacer, and 33 spline spool with bearing kit. Richmond 4.88 gears. All parts are new but rear will need to be assembled. $750 cash, sorry too big to ship. Might split up. Post hear if you want it. big
bighead is offline   Reply With Quote
Old 01-19-2009, 12:53 AM   #2
71chevytruckguy
71chevytruckguy's Avatar
Re: 12 Bolt Drag Rear
I'm interested in the spool, c-clip emlinators, and maybe axles pending prices. Thanks. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 01-26-2009, 11:56 PM   #3
71chevytruckguy
PM sent. Chris.
