Old 12-26-2008, 05:00 PM   #1
lotik
drag it like you stole it
Rearend Placement
I need a measurement from the rear of the frame to the center of the rearend. I removed the trailing arms and cut out the crossmember before measuring. I guess I will learn. I need to figure out the stock placement of the rear end again. Its a '67 Short.
Thanks for the help in advance.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 12-26-2008, 05:58 PM   #2
john
member #16
john's Avatar
Re: Rearend Placement
I would use the wheelbase. Then it would be correct.
john is offline   Reply With Quote
Old 12-27-2008, 06:47 PM   #3
lotik
so that's from center of hub on rotor to center of hub on axle?
Old 12-28-2008, 02:40 PM   #4
john
member #16
john's Avatar
Yes 115" SWB
127" LWB
Old 12-28-2008, 02:52 PM   #5
lotik
thanks john
