Old 12-26-2008, 07:48 PM   #1
66burban
Coil Over to Leaf Spring...
Converted a '66 from coil springs to leaf springs?
66burban is offline   Reply With Quote
Old 12-26-2008, 09:31 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Coil Over to Leaf Spring...
66burban-Welcome to the forum.
What are you trying to accomplish? It can be done, but is it worth it?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-26-2008, 10:07 PM   #3
66burban
I would like to convert the coil suspension on my 1966 Chevy Suburban (Carryall) to leaf springs. I was just wondering how to do that.
Old 12-26-2008, 10:25 PM   #4
desertrat
desertrat's Avatar
You will need to get ahold of spring hangers, shackle hangers, shackles and leaf spring pads to weld on to youre axle housing.
I don't know if anyone makes the front spring hangers ( I'm sure someone makes them).
If you are planning on a lift I would go with the shackle flip kit by either DIY or ORD which gives you 4" of lift .
I would assume you want to lift it?
Thats the only reason I can see wanting to change it out. Which is why N2TRUX was asking.
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 12-26-2008, 10:28 PM   #5
66burban
Well its only 2wd so I think I would go for a drop before a lift. Anybody know of any drop kits?
Old 12-26-2008, 10:37 PM   #6
desertrat
desertrat's Avatar
There is alot of options but I would not suggest going with leaf springs if you are going to lower it.
There is alot of variables if you want to drop it. Like how low you want to go for starters.
I would suggest doing some searching here in the "suspension forum" because there is alot of info here.
Oh , almost forgot Welcome to the board from Pahrump, NV
Old 12-26-2008, 10:38 PM   #7
66burban
Ok thanks for the help guys, I shall do some searching.
Old 12-27-2008, 01:35 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
If you are trying to lower it, check with the forum vendors. There are several that offer lowered coil springs. You can also put a set of air bags in place of the coils and have an adjustable suspension.
Articles-
"Refining Sierra"
Old 12-27-2008, 11:59 AM   #9
SCOTI
SCOTI's Avatar
Obviously, there's a fair amount of work involved in the swap. Is there any particular reason for wanting to go through the trouble of swapping from one to the other?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-27-2008, 10:15 PM   #10
66burban
Umm, no I was just wondering.
Old 12-27-2008, 10:50 PM   #11
SCOTI
SCOTI's Avatar
In that case.... it's a simple swap of bolt-in parts after removing the 50 or so factory rivets.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
