Old 12-26-2008, 10:22 PM   #1
chip46wis
67-72 disk-master Pictures?
Ok I will try this another way,using a stock 1971 master booster on my 69 what is the line routing from the master to the disks.The master has a smaller line at the front (large bowl)----- I always thought disk required more fluid than drums.ANYONE have a pic of their stock master with lines? THANK YOU!!!! Chip
chip46wis is offline   Reply With Quote
Old 12-26-2008, 11:15 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: 67-72 disk-master Pictures?
Factory Disc brake master cyclinder.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
