Old 12-26-2008, 11:43 PM   #1
c10concepts
c10concepts's Avatar
Accelerator Pedal Rod
I keep looking for this part and I find one similar but it says its for a 6cyl does anyone know if this will work anyway if not can anyone tell me where to find the right one....I have looked on many websites and catalogs and they all say the same thing....Any info would be appreciated....
1970 GMC SWB Under construction
1968 C10 SWB Big Window (SOLD)
1999 GMC Sierra Z71 SLT (SOLD)
c10concepts is offline   Reply With Quote
Old 12-27-2008, 01:24 AM   #2
c10concepts
Re: Accelerator Pedal Rod
Bump Anyone know?
Old 12-27-2008, 01:27 AM   #3
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
I am not sure. If you posted a pic, I think we might have better luck helping you.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 12-27-2008, 01:29 AM   #4
c10concepts
Yeah Ill take one its the rod that goes from the pedal assembly to the carb...
Old 12-28-2008, 03:08 PM   #5
c10concepts
Here is a pic I found if you look at the carb its the rod running to it from the pedal assembly....
http://i88.photobucket.com/albums/k1...ky9/ed13_3.jpg
Old 12-28-2008, 03:36 PM   #6
JimKshortstep4x4
I believe the 6 cylinder rod is longer.
I ended up making one out of 1/4" rod and threading it for the fitting.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-28-2008, 03:42 PM   #7
Bob D
Rolled on Paint Club
Bob D's Avatar
I also had to make my own with 1/4" threaded rod, got the idea from someone on this board. Bought a swivel joint for the carb end from here: www.mcmaster.com I also slid the rod into a cut length of coated brake line to make it look better.
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 12-28-2008, 03:53 PM   #8
c10concepts
You would think they would make something like this for the aftermarket...Mine is all bent up and when the truck was running it didnt fit with the edelbrock carb but it did fit with the quadrajet that was on there before my dad took it off....
Old 12-28-2008, 03:55 PM   #9
Bob D
Bob D's Avatar
Here is mine, with the Performer carb. :
Bob
SB 355ci.
Smog heads
Summit 1102 cam
Old 12-28-2008, 03:59 PM   #10
c10concepts
Nice set-up I know when I get my motor back from the shop this is going to be my biggest hassle....
