fowled plugs
I just got new plugs a few months back and i pulled them today because it was missing and they were black. They were fouled and one of the plug tips was bent and almost just touching causing almost no gap.I don't know what could have caused this. For now i replaced the plugs for some hotter ones and am going to see what happens. What could be causing them to foul?
1969 red k/10 with sb350 4.11 gear ratio, front disk, 3 speed automatic Last edited by 1969 k/10; 12-27-2008 at 06:17 PM. |
Re: fowled plugs
chickrns are fowl
fouled spark plugs are another animal// is it dry powdery soot black or wet tar like black? dry black powder type of fouling is an overrich condition normally from poorly tuned carb//black tar like is bad rings or valves causing oil fouling as far as the electrode is concerned ,was probally on installation that it got hit
Re: fowled plugs
This is new to me.I`ve never seen a spark plug affected my ducks or any other fowl.
![]() All plugs looked the same?Wet black or dry black?You are sure the one ws gapped properly in the first place?Did the truck seem to run normal all this time? It could be carburator adjustment,timing,or week ignition if it`s dry...carbon=unburnt fuel.If it`s wet you`ll prolly find some low compression from worn valvetrain,piston ring,cylinder walls.Does it puff smoke when started or when pulling off after idling?Could be valve seals or guides. All that said,you may have just had too cool plugs and what you`ve done may be all it took.Is the motor pretty much stock?Any add-on goodies sittin`on top?What plugs did you have and what`s in there now? EDIT:I sure type slow.There were no replies when I started. ![]()
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-27-2008 at 07:58 AM. |
Resident of Here
Re: fowled plugs
Were all of them fowled or only a few?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Re: fowled plugs
Haha I was thinking about birds too
Re: fowled plugs
Haha i feel dumb now, but anyways they were all FOULED and it was a wet black. It it possible that i smashed the plug on installation causing it to bend. ?The timing is at 8 degrees and the plugs were autolites that were already 1 step hotter. As far as goodies i just have an Edelbrock carb. and intake
1969 red k/10 with sb350 4.11 gear ratio, front disk, 3 speed automatic |
Re: fowled plugs
do you have a properly installed PVCsystem?
laying low
![]() Join Date: Mar 2001
Re: fowled plugs
You put you some AC plugs in there and give that carb some attention and I bet it smoothes right out.
![]() Make sure the choke is operating right.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: fowled plugs
I`d definately be chicken the pcv/crankcase venting.Is it gobbling alot of fuel?A quacked ring would cause such a problem but not all cylinders at once.Same with valvetrain.Duck under the hood and chick how hot the spark from the coil is.I egrit I`m not closer.If you were heron the east coast I`d come over and have a looksee.Is it puffin any smoke?I`d peep in my mirrors while it`s running.When you goose it off idle and it smoked it`s your guides or seals from no lead.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-28-2008 at 01:02 PM. |
Re: fowled plugs
I agree with Boog hei put r45ts, points put r44t!!!
Old Skool Club
![]() Join Date: Jun 2001
Re: fowled plugs
I used to have problems with plugs fouling on my 350. Carb was running rich (Edelbrock 1406), so I changed to an Edelbrock 1901. It was immediately a leaner-running carb, that forced me to add a heat shield to the starter solenoid. It has headers and an HEI. Changed distributors when the GM junkyard HEI broke a wire to the reluctor within the distributor. Changed plugs to AC Rapidfires and have never had another plug to foul....oil or gas-related. Timing on my engine is set to 10-degrees BTDC.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: fowled plugs
the people i work with at autozone they said bosch plugs foul up real quick... the ones that only have the one prong..they say those arnt to good... but other then that i dont know
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#13 |
Re: fowled plugs
Hmmm
#14 |
Chevy nut
Re: fowled plugs
I have found that the older...I should say higher mileage motors....tend to foul plugs. I was always buying the cheap plugs. I started buying the more expensive plugs...getting away from the AC's and Autolites. I wasnt changing plugs as often.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
#15 |
Chevy nut
Re: fowled plugs
Chicken?? Do you think the PVC has gone FOWL?
#16 |
Re: fowled plugs
^Did you miss the rest?
![]() Since they are wet,are they oily or smell more like gas?If it`s gassy smelling then I`d look at plugs,carb,etc.If they are oily it`s engine wear.I hotter spark and leaner carb helps compensate,but not the solution. BTW,Bosch is one of the best products in the world.Which non-qualified person did you speak to at Autozone?Bosch may very well be the best aoto electrical company in the world who know only makes premium products.I just like an American name in my American stuff.Don`t run Oriental name tires either.ACs have been doing the trick since day one for me.You just need the right ones.If which plug you use makes that much diferent,you have bigger problems anyway.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-28-2008 at 12:59 PM. |
#17 |
Old Skool Club
Re: fowled plugs
When I was selling auto parts at Auto Shack (a while back, right?), I learned that there are parts people who will perpetrate a lie, based on what someone told them to be gospel truth.
Each and every one of us knows someone who we trust to always know the answer to our questions, yet there will be times when their answer may not be totally correct. How well any spark plug performs in an engine is going to be relative to the state of tune and the overall mechanical condition of the engine. It doesn't matter if it's a lawn mower engine or a AA/FD. Reading the condition of your spark plugs is a science that the engine pros use to help the "big boys" out-do the competition....whatever that competition may be and whoever the competitors are.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 12-28-2008 at 01:39 PM. |
#18 |
![]() Join Date: Sep 2005
Re: fowled plugs
post some pictures of the plugs and we can tell you what is goin on
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#19 |
I am a Referee of life.
Re: fowled plugs
In the Back of almost any "Hayne's" manual there is a chart that will be the beginners guide to reading spark plugs.It is a good place to look to help learn which plug fowling problem you are having.
BTW is your shotgun a full choke model?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#20 |
Trucks N Tranzams
Re: fowled plugs
Here is a guide to spark plugs and compression that I have found very useful.
If your plugs are black, Your engine is too rich or burns a lot of oil. I hate to break it to you guys, but NGK and Bosch are the #1 spark plugs out there. All brands are close in comparison, but based on the amount of research and development conducted, NGK and Bosch are by far the best. This link is useful too. http://www.sparkplugs.com/ Here are the recommendations from edelbrock. I believe the plug seats are flat, so you should use the washers (if they are tapered seats, you don't use the washer...) Under 9.5 to 1 Compression Champion ---------- RC12YC / 2071 NGK --------------- FR 4 / 5155 OR BCPR5ES / 6130 Autolite ------------ 3926 Motorcraft --------- AGSFP52 Accel Shorty ------- 0416S Up to 10.5 to 1 Compression Champion ----------- RC9YC / 2075 Autolite -------------- 3924 NGK ----------------- FR 5 / 7373 OR BCPR7ES / 3330 Accel Shorty -------- 0414S 11 to 1 Compression Champion ------------ C63YC / 796 NGK ------------------ R5672A-8 / 7173 12 to 1 Compression Champion ------------- C61YC / 785 NGK ------------------- R5672A-9 / 7405
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
#21 |
laying low
Re: fowled plugs
NGK or Bosch? Nah. Edelbrocks' choices are his opinion or those of his employees.
We all drive GM products here and GM has long used AC Delco brand parts. I have to believe considerable research was done before GM chose this brand. They are made to GM's standards. I have used only a couple of other brands once or twice in my many years but have always came back to AC. The AC plugs in my 2 97 trucks are said to be good for 100,000 miles. From the looks of them I believe they will do that and more. In the end I feel like if AC is good enough for the General it's good enough for me. That's my opinion on it! ![]()
#22 |
Re: fowled plugs
![]() ![]() Now,how was it that saying went? Opinions are like ... Everybody`s got... Maybe someone should start a spark plug poll or a thread asking opiniions on plugs.This one is about what`s fouling his plugs.It ain`t the plug brand.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-28-2008 at 07:01 PM. |
#23 |
Re: fowled plugs
Autolite plugs the imports.
#24 | |
Chevy nut
Re: fowled plugs
#25 |
Re: fowled plugs
Autolite= neverlite plugs
