12-27-2008, 03:48 AM | #1 |
250 with a turbo 350
What would be the best way to swap a 3 speed transmission (on the column) for a turbo 350. I have an idea on most of the problems like drive shaft and transmission cross member. But the one thing that i am stuck on is how to do the kick down cable, since my single barrel has no place for a kick down cable? Oh yah this isn't for my truck but my 64 nova.
12-27-2008, 12:28 PM | #2 |
Re: 250 with a turbo 350
I running without the cable hooked up and it seems to be ok(we are not talking break neck speeds in a 250) There are kick down bracket out there for the 250. I had one and cut it up to make thottle linkage for my hot rod.
12-27-2008, 01:34 PM | #3 |
Member #1049
There was a factory t350 put in some vehicles, I found a t350 complete kickdown setup in a 74 nova,.. I also have seen them in Chevelles and later 70's trucks.
The only issue that I know if is your Nova has a throttle rod instead of a cable which was used in 68 and new cars and 71 and newer trucks.. both used different bell cranks bolted to the intake manifold.. |
12-27-2008, 02:53 PM | #4 |
"Trucks with Class"
This is a 71-2 truck with cables, not rods.
Sometimes the Craftsman "choke enhanser" is the only way I can get those 1bbl carbs to run! Last edited by PICKMUP; 12-27-2008 at 02:56 PM. |
12-28-2008, 01:09 AM | #5 |
Thats what I needed to know.
thank you |
12-29-2008, 01:30 AM | #6 |
Something I have to say is I get better information and from nicer people here then any other sites.....
Thanks. |
