Windshield Washers keep freezing up
Hey guys
I have a 86 chevy K10 and it has the WW sprayers on the wiper arms, and they keep freezing when it gets really cold, regardless of how much methenal hydrate I put in the fluid I was wondering if I could put the 81-84 washer sprayer on that mount in the cowl and spray up on the windshield from there. I haven't had the cowl piece off, and I was wondering if the proper mounting point are there for these sparyers, and I can route rubber lines to them in the cowl. This way they won't be afftected by windchill, and freeze on me.... There is a small piece of brass tubing that come up at the arm base, for the rubber lines to go the the wiper arms but there to close to the wiper arms for the other lines to bolt to any information is benificial Thanks Cameron
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
Parts and more parts
Re: Windshield Washers keep freezing up
YES the cabs are the same, if you want to change it CAN be done. I have an 84 and an 86 truck in my shop, the only difference is the design of the washer hose connections.
Thanks thats what I need to hear....I will order the nozzels
Duro
In the Forgotten far North.
![]() Join Date: Jul 2007
I did the same to my '90 burb. Looks old skool but works alot better.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
I accually like the look better, less things on the wiper arms, and they don't freeze up on me.
Also I have the old school wiper arms with the tab on the back, whats the secret to pulling them off?, they are original and never removed since new Thanks Cameron
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project Last edited by Duro5341; 12-27-2008 at 01:51 PM. |
Use a hook tool on the opposite side of the mounting point from the arm itself pull back on the retaining clip and wiggle the arm off at the same time
Right turn Clyde
Orange RainX washer fluid is pretty nice to use. I have been pretty pleased with it and its only 3-4.00 a gallon.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
One shot, one kill.
Duro: You might run into an issue with the cowl. The cowls are different for "fluidack" arms as opposed to "nonfluidack" arms, I'm not sure though. To remove arms, lift arm away from the W\S, move tab away from arm, with tab out release arm (it will set on the tab) then wiggle arm off. New arms may or may not have the tab, mine don't and they are a PITA to get on and off. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Crew Cut
i have never had this problem. just can't understand? may try a change of address. lol,lol,lol. oh sorry just could not help it. you know how us southern smarta$$$$ are. good luck
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
#10 | |
Duro
There is a simple little tool that is used to remove the wiper blades. Just about every parts store carries them, where I live, but it can also be made out of a piece of strap metal.
