Old 12-27-2008, 12:14 PM   #1
srsummers
65 factory power steering?
I bought a 1965 or 1966 long bed 3/4 ton truck for parts. It has power (drum) brakes and power steering. I haven't seen power steering like this before. It has a hydrolic steering dampner not a hydrolic steering gear box. Are these any good? Should I put this set up on my 65 short bed or go with a more modern hydrolic steering gear box? Would this older style power steering pump work with a newer power steering gear box?
srsummers is offline   Reply With Quote
Old 12-27-2008, 12:22 PM   #2
joe231
joe231's Avatar
Re: 65 factory power steering?
I believe it is called "power assist"
I see them on ebay from time to time, not cheap
I don't know how well it works, you should be able to adapt the old pump to a newer steering gear, but the newer pumps are cheap
I know you can use the brackets to mount a newer pump to a 283-327
CHEVY ONLY
Old 12-27-2008, 12:32 PM   #3
LILRED66
LILRED66's Avatar
Ditto what joe231 says. Power-assist steering was available on the 4-5-6 Chevy trucks, similar to the car set-up of the same years. This system used a hydraulic cylinder, in lieu of a power steeering gear box, to achieve the power feature. They are rather pricey, per what I have seen on eBay.
I have a few trucks that have this factory set-up on them and they work fine. The pump, mounted to the engine, is the same Saginaw old style pump. If it works properly, you can use it with the factory set-up or utilize the pump with a Saginaw power steering gear box, with the proper hoses.
If you like factory, which I prefer, it can be used successfully. Keep us posted on your decision.
PS, welcome to the forums from Kansas City, KS. Remember to post early and often, especially photos. Happy Holidays.
LILRED66 is offline   Reply With Quote
Old 12-28-2008, 11:03 PM   #4
srsummers
Yes, the power assist still works...it just leaks. Can you still get parts for that set up? I haven't seen any yet?
Old 12-28-2008, 11:12 PM   #5
LILRED66
LILRED66's Avatar
Truck and Car Shop sells the following:
Item #63-14106 - Power Steering Control Valve Seat Kit for $13.00
Item #63-14107 - Power Steering Hydraulic Cylinder for $119.00
Item #63-14108 - Power Steering Cylinder Repair Kit for $13.00
Item #63-14109 - Power Steering Cylinder End Mounting Kit for $7.00
All of these items are on Page 107 of the May, 2008 Truck and Car Shop catalog.
I hope this information is helpful and good luck with your project.
Happy Holidays.
Old 12-29-2008, 10:47 AM   #6
srsummers
Talking Re: 65 factory power steering?
Thanks for all of your help Lilred66. I hope to get some pictures of my project posted soon.
Old 12-29-2008, 05:50 PM   #7
83burban
I recently restored this system. I got all my steering gear from this guy. Great products, very helpful, I was very impressed and pleased with his work. Pricey...but I am doing a full frame-off and want everything to be perfect.
I plan on getting custom stainless lines made using the old ones as a template as soon time permits
www.chevyps.com
83burban is offline   Reply With Quote
