Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-27-2008, 02:22 PM   #1
phipp13
THE DAMN YANKEE
phipp13's Avatar
One last burnout
i made 1 more dump run with the Damn Yankee today with my 19 yr old, he's up for a couple weeks to chill with his pop and help me with the build. soo i figured i'd 1 last burnout before before i take it down. it was a good one since it has no rear brakes
phipp13 is offline   Reply With Quote
Old 12-27-2008, 05:57 PM   #2
phipp13
THE DAMN YANKEE
phipp13's Avatar
Re: One last burnout
triing to add pics and screwed it up
Old 12-27-2008, 09:23 PM   #3
LuckyHenriksen
LuckyHenriksen's Avatar
awesome
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-27-2008, 09:25 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Sweet.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-28-2008, 12:00 AM   #5
Chevymann1968
Chevymann1968's Avatar
I did the same thing but didnt get it on video or camera!!!! What are the plans for it???
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Chevymann1968 is offline   Reply With Quote
Old 12-28-2008, 01:25 AM   #6
phipp13
THE DAMN YANKEE
phipp13's Avatar
plans are a blown 383, built turbo 400,1/2 tubbed and a 9" braced rear, ladderbars& coilovers. check out my build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=318731
Old 12-28-2008, 07:07 PM   #7
meansting04
meansting04's Avatar
sweet!!
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 01-05-2009, 08:58 AM   #8
djracer
djracer's Avatar
It sounds good but keep the trailing arms! They work well.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-06-2009, 12:11 AM   #9
phipp13
THE DAMN YANKEE
phipp13's Avatar
DJ the biggest reason why i'm using ladderbars is because my trailing arms are rusted out. There is rust inbetween the 2 channels and due to the exfoliation there are buldging areas that are nothing but rust and it would be impossible to remove all the rust and have serviceable trailing arms. did you see my home made ladderbars? also i bought the 4130 3/4" heim joints and 2 4340 double adjusters so they will be double adjustable for tuneability. also i have 1 rt &1 lft threaded heimjoint on each end of my panhardbar so it will be easy to adjust and get it lined up. hell here is a couple of pics
the nut was tacked, it is fully welded now
I made sure i put a few diagonal bars in threre for stiffness. this is 1.125 4130 tubing .125 wall
after the brackets are welded to the rear they will be welded together with a strap for added strength. all brackets are 4130 also. the only mild steel is the 2x4 .125 box tubing used to back brace the rear. hopfullyi won't have to trash this stuff as i have a lot of time and $ tied up in this setup.
Old 01-06-2009, 08:14 AM   #10
djracer
djracer's Avatar
10/4 good luck with it. I like ladder bars I just think the trailing arms work fine when they aren't rusted of course.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
