Old 12-27-2008, 05:44 PM   #1
yellowGT
yellowGT's Avatar
Rear-end conversion question
my recent 68 that i purchased has a 12 bolt rearend just like my 69 that i have. The 69 has been converted to 5 lug so i imagine someone just changed out the axles in it. Is that possible? Could i change the axles from a 10 bolt truck to a 12 bolt. Because the 10 bolt rearend comes from a 81-87 chevy and the u-bolt plates are on the wrong side and they dont have the hole for the bar therefore I just cant change out the rearends. I would think that if they are spline the same it should be a cake walk. Does anyone know the spline count for both before i start popping covers?
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 12-27-2008, 05:49 PM   #2
Cyclone
Cyclone's Avatar
Re: Rear-end conversion question
You could use that 5 lug rear end by utilizing one of these kits. I hear the axle swap wont work, there different lengths.
Cyclone is offline   Reply With Quote
Old 12-27-2008, 07:17 PM   #3
66skylarkpost
66skylarkpost's Avatar
no way . the ten bolts you are refeering to are have 28 splined axles and the 12 bolt have 30
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 12-28-2008, 03:38 AM   #4
yellowGT
yellowGT's Avatar
so the only way to make the conversion without changing rearends would be to find a rearend from a 72 truck with 5 lug. If thats the case, changing the whole rearend from a 72 would be just as easy.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 12-28-2008, 12:12 PM   #5
Cyclone
Cyclone's Avatar
You could do an axle/drum swap.
Old 12-28-2008, 07:39 PM   #6
yellowGT
yellowGT's Avatar
yeah thats one thought i ran into last night....pricey though
thanks guys
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
