Old 12-27-2008, 09:35 PM   #1
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
Sagging
911 question,
I resently change the bushings and the springs on my 84 Silverado and now it's saging again! Does anyone know what the problem might be?
Smoke_Dog is offline   Reply With Quote
Old 12-28-2008, 10:34 AM   #2
thump16
thump16's Avatar
Re: Saging
These two posts should answer your question.
http://67-72chevytrucks.com/vboard/s...hlight=leaning
thump16 is offline   Reply With Quote
Old 12-28-2008, 04:52 PM   #3
Alex1
Alex1's Avatar
Re: Sagging
Yeah, my rear lpassenger leafs are real weak causing my truck to lean over.
Alex1 is offline   Reply With Quote
Old 12-29-2008, 02:29 AM   #4
slugish
Slugish
Re: Sagging
used 1 in spacers under my front coils to correct my leaning problem . under the sagging side of course.
slugish is offline   Reply With Quote
Old 12-29-2008, 03:05 AM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Sagging
my truck is the same way some times, or the front end sits up real high "no weight in the bed" and then next time I drive it will sit level, and this is in the same spot on my drive way when I look at it
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
