12-28-2008, 01:03 AM | #1 |
67-72 parts collector,…
Need a source for GREEN carpet
My carpet in the blazer is original. It's not in too bad of shape,... but I'd like to replace it.
Is the green replacement carpet the correct color? (or incorrect like the dash pads) And who should I get buy from? Also,... here's a couple pics of the rubber mat under the carpet. It follows the contour of the floor and I looks like it's original. I've never seen this before.
12-28-2008, 01:42 AM | #2 |
Blaze-Air
Re: Need a source for GREEN carpet
"The Truck Shop" in Crossville TN... I just went to his link, and it's under construction. I will try to get a #. The owner(Jerry Brown) is into correctness, at least as much as possible. He should at least point to right direction...Rubber mat, had them under all my trucks, at least the original one's
12-30-2008, 11:32 PM | #3 |
I also had the same looking mat in my 71 k5, not sure if original but it was trash, I've got Jerrys # some where I'll try to look it up
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
12-30-2008, 11:38 PM | #4 |
Thank. Any info would be great. I just don't want to order the wrong stuff.
12-31-2008, 09:51 AM | #5 |
The rubber mat under the carpet is a rare item to find in decent shape...it is installed at the factory and is an OEM piece.
It contours to the bed floor and allows the carpet to rest in there flat instead of having the bed 'ridges'. The downfall they have - is that they can trap moisture and rust the bed out in certain conditions if not taken care of. |
