12-28-2008, 06:13 PM | #1 |
350/700r4 hook up
Guys, I'm planning on buying a new 350 crate and a new700R4 to complete the drivetrain on my ride and was curious about hooking it up myself. Aside from needing to cut the drive shaft, how difficult is hooking the two up to each other and to the truck? I'm pretty mechaniclly inclined but not sure if i should leave this up to a professional. And if so what am i looking to spend on labor(ballpark) for someone to do this for me, assuming i walk in with the engine and tranny? Any advice would be much appreciated. THANKS!
12-28-2008, 06:41 PM | #2 |
Re: 350/700r4 hook up
TV cable adjustment is critical for proper trans operation. If you don't have stock carb/throttle body/cable/connections, that can be tricky. Otherwise, the install is fairly easy - the trans crossmember will have to move back a couple of inches. If you still have the old manual crossmember below the firewall, that may have to be cut out for clearance. I used floor cable-type shifter to avoid linkage issues.
As for paying for install, I'd get quotes - probably 10+ hours labor at whatever hourly rate they charge (then add 20-30% fudge factor). |
12-28-2008, 10:05 PM | #3 | |
Let us know what you end up doing.
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
12-28-2008, 10:25 PM | #4 |
Steverino is right on moving the xmember back a few inches. The 700r4 bolts right into place except for the torque converter bolts which are metric... the tranny is all metric. I used the stock linkage, but I did have to relocate the brackets slightly for that as well. Bowtieoverdrives.com has some good conversion kits for the 700r4, TV cable bracketry for different carburetors.
12-28-2008, 10:57 PM | #5 |
64c20crewcab already mentioned bowtie, they have lots of tech articles there...
some more information articles: http://www.tvmadeez.com/article/index.html how the TV control system communicates to the Th-700R4 and Th-2004R transmissions. ---- http://purplesagetradingpost.com/sum...o/700R4p1.html adjusting Th-700R4 transmissions. ---- more parts options: http://www.tciauto.com transmissions and assorted doodads ---- You should also dig around in the faq/ faq truck tech section here at this site! Good luck! -W |
12-28-2008, 11:31 PM | #6 |
Woog strikes again...thanks for the links. I have a few kinks to work out on a few of my 4-5-6 Chevy truck projects and this information will come in quite handy.
12-29-2008, 01:57 AM | #7 | |
CHEVY ONLY |
12-29-2008, 05:15 AM | #8 |
There is also another option from this place concerning the TV cable. I haven't used them or heard from anybody that has. Maybe somebody can chime in on them.http://bowlertransmissions.com/uploa...shiftFlyer.pdf
12-29-2008, 02:50 PM | #9 |
Resistance is Futile
C'mon Joe, one under each arm....its not that tough.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
12-29-2008, 02:56 PM | #10 |
CHEVY ONLY |
12-29-2008, 05:54 PM | #11 |
I have a good guy that can help you out here. He is doing the motor in my suburban right now for 1750 installed. He rebuilt the motor using all new parts, bigger valves, an RV cam and will take out the old and install the new, break it in, drive it 100 miles to get everything right and tune it up nice and perfect.
No core charge, and he said he'll back his work in the event of a failure. Let me know if you want me to give him your info. His dad did the transmission in my truck as well, 700r4 and it works flawlessly. |
12-30-2008, 01:31 PM | #12 |
Thanks for all the advice guys, I really appreciate it!
62C20- I might take you up on your contact, I'll let you know. Thanks!!! |
