Old 12-28-2008, 10:23 PM   #1
custom72c20
custom72c20's Avatar
Motor and tranny swap questions
Ok here goes. Im wanting to put a big block and th400 trans that I have in my 72 C20. My truck has a 350/350 in it right now. Can I just buy the engine towers and a new tranny crossmember and bolt it in? Will i run into any clearance problems with the cab, etc...? All help is appreciated. Thanks
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 12-28-2008, 10:28 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Motor and tranny swap questions
I think you got it all covered. Not sure though.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-28-2008, 11:08 PM   #3
primered_junk
ASE master tech/machinist
primered_junk's Avatar
You can run the small block towers if you swap them side to side, you have to drill 2 holes, but it works great. I did it on my 71 GMC 3 years back, never had any clearance issues at all, it got close on the drivers side header but never made contact. I have pics if you need them.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 12-28-2008, 11:33 PM   #4
custom72c20
Thanks for the input. I already have the towers and crossmember though. I just wanted to check to see if the tranny was going to clear the cab due to it being a low hump. Thank you again.
Nick
Old 12-29-2008, 02:08 AM   #5
custom72c20
Anyone else have any info?
Nick
Old 12-29-2008, 02:12 AM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I see no reason for it not to fit
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-29-2008, 02:16 AM   #7
custom72c20
ok cool. Now i just got to do it. haha
Nick
Old 12-29-2008, 07:53 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done three big block conversions now. I found that a big block and turbo 400 will fit a low hump truck if you have fresh body mounts. Old saggy body mounts will allow the cab to rub the trans housing.
Old 12-30-2008, 12:00 AM   #9
custom72c20
Thank you for that. Good thing I have a new set of body bushings.
Nick
