53 chevy fender braces
Hi, ol street rodder here but new to the truck scene. I purchased a 53 chevy 1/2 ton from the original owner so its all compete and in primer. My question is about the two fender braces that go from the left/right fenders to the fire wall. I know what they are used for, but I've noticed that some custom trucks eliminate them. So are they essential for the fenders to line up etc. and how are they removed without having the fenders droop or not line up. I would like to remove them when I put the truck back together, thanks for the help.
#2 | |
Re: 53 chevy fender braces
if you use their inner fenders they attach to the frame with a small bracket, that aslo gives stability.
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck Last edited by 50adrod; 12-29-2008 at 08:05 AM. |
#3 | |
Your build is looking great, the seats look good in the cab. Thanks, Rob |
#4 | |
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
I dont have any. My front end might have a small wiggle to it, but I dont have inner fenders or anything else either.
you might try getting chrome rods as a dress up. but one of the weakest points on these trucks is the entire front end mounts to the 2 bolts on the bottom of the the radiator support. my original radiator support was missing 3 inches of channel from metal fatigue. my 2 rods had spider cracked my firewall where they mount. so you do need these unless your reenforcing your radiator mount some how
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
Hi, thanks for all the good info, I think I'll look into the new core supports, I just don't like the look of the braces going thru the engine compartment, thanks again.
I didnt use them at first but I had issues with fender/ hood alignments so I ordered the polished Stainless Steal rods and installed them. Everything lined up so much nicer and the really dont look bad at all.
I have a home made 1x2 core support as well fyi and last time the truck was together had damn near perfect gaps. I also plan on ading pieces to go from the bottom of the grill to the core support or frame.
