Old 12-29-2008, 12:13 AM   #1
ezekiel
Question Camaro clip or 86 frame swap?
Howdy Y'All!
Happy New Year!
I am planning out a new project with my 56 TF and I would like to have IFS when I'm done.
There's two different routes I could take:
Option 1: Use the frame from my 1986 GMC LWB 1/2 ton and mount the cab and long fleetside on it.
Option 2: Use the original frame and install a Camaro clip.
I know that people on the board have used both methods.
In terms of time investment, which method would you advise?
Thanks Guys!
Zeke
ezekiel is offline   Reply With Quote
Old 12-29-2008, 02:29 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Camaro clip or 86 frame swap?
Originally Posted by ezekiel View Post
Howdy Y'All!
Happy New Year!
Thanks Guys!
Zeke
If you're wanting to have a low stance, and had to choose between the two options listed, I would recommend the camaro subframe. The C10 chassis would have too wide a trac-width up front.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-29-2008, 02:41 AM   #3
nuke1
nuke1's Avatar
i agree with Nathan, the trac width is too wide for the old truck, the tires will be hitting the fenders, and the camaro subframe intall is easyd, i just installed one into the 58 apache in my sig, by installing the camaro clip, i lowered it 7 inches in the front. it is up to you but i know my choice.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-30-2008, 02:53 AM   #4
ezekiel
I didn't know the track width was significantly different with a TF truck. Maybe I should confirm that detail.
Otherwise, I guess I should look for a donor camaro.
Nuke1, since you're a fellow Canuck, how much did your donor cost you?
Thanks Guys.
Old 12-30-2008, 01:36 PM   #5
dieseldr4
honestly, have subframed a few 55-57 trucks and its really not that hard.. and you get the right track width.. i think that the 64-67 chevelle frontend is the best fit... i know fab work is fab work, but it does take less... and afterwards when you rebuild the suspension you can get a sweet disc brake drop spindle kit off of ebay for 250.00 to 300.00 and whamo youre dialed... the last one i did with an early chevelle kit, the c notched the rear and flipped the rearend onto the top of the springs.. i had a 1000.00 budget to do the truck and it handles like its on rails... hope this helps, tom
dieseldr4 is offline   Reply With Quote
Old 12-30-2008, 02:18 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Having done a C10 IFS on a 58 it is a bit to wide. You can use an offset wheel but it will need to be a 16" wheel to clear the disc calipers and tie rods. Otherwise the wheels will hang out of the fenders and then you still can't slam the truck even with the offsets.
The plus is you have a truck suspension if your daily driving and using it as a truck.
dwcsr is offline   Reply With Quote
Old 12-30-2008, 02:29 PM   #7
ezekiel
You guys are very convincing. Time to ditch the 86 GMC.
So, would this camaro be a suitable candidate?
Old 12-30-2008, 02:51 PM   #8
bensimmons_05
bensimmons_05's Avatar
Requiring less fabrication is also a dropped original axle. there are many disc brake kits available. As a guy who is not a master welder I chose this option.
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 12-30-2008, 04:25 PM   #9
Kim57
Kim57's Avatar
Zeke
Here is a pic of the 57 I'm building with a 67 chevelle clip. You can see how the clip lines up with the original frame. Good luck with your build.
Kim
Kim57 is offline   Reply With Quote
Old 12-31-2008, 01:32 AM   #10
ezekiel
I've found the following track width information at the
http://www.chuckschevytruckpages.com/models.html
Model | Front | Rear
C/10 & 20 | 65.8" | 62.7"
and just to be complete, here are the frame specs for the same
http://www.chuckschevytruckpages.com/framespecs.html
and if the information at http://50chevy.freeservers.com/Suspension_Widths.html is correct then the Task Force trucks have a track width of 62".
Since the Camaro (1976 - 1980) has a track width of (front/rear) 61.3-60.5 then I now understand why dwcsr recommends not using the 1986 GMC frame.
I suppose it might work if I were building a lifted 4x4 but not a street truck.
Hopefully, all this information is accurate.
Old 01-01-2009, 03:32 PM   #11
56chevy1300
56chevy1300's Avatar
Here's mine, its a 74 Trans Am sub. Stop by sometime if you're ever in Edmonton.
56chevy1300 is offline   Reply With Quote
Old 01-05-2009, 12:50 AM   #12
nuke1
nuke1's Avatar
i got my clip for free from a friend, but i can get another for a couple hundred, that camaro you saw on kijiji, if you could get it for a few hundred, it is worth it, b/c u have the diff also. yes that info is correct, i wanted to o that route also
James
1968 GMC "HAVOC"
1986 GMC "Frank"
