12-29-2008, 03:58 PM | #1 |
Front crossmember...
What year front crossmember will bolt into my 1966 so I will have 5 lug and disc brakes?
12-29-2008, 04:50 PM | #2 |
One day...
Re: Front crossmember...
73-87 just have to drill a couple holes in frame.
12-29-2008, 05:00 PM | #3 |
What would you reccommend I do about the back?
12-29-2008, 05:04 PM | #4 |
One day...
Depends on your plans, i was planning on bagging mine anyways so i found a different rearend, i have a ford 9 with disc brakes from a lincoln versi. You could find a 12 bolt and buy the conversion kit to bolt up to the trailing arms. That would save from buying axles or having them drilled.
12-29-2008, 06:10 PM | #5 |
Replacement axles/drums in a 5-lug pattern. Check out ECE, GMC Pauls, or Classic Hearbeat for conversion stuff (kits). I used Moser axles for my 6-lug 68 rear end & then swapped to 71-72 5-lug drums w/o any problems.
