12-29-2008, 05:47 PM | #1 |
Knuckle head
Help!?!? ART Strong Arms
I have had the control arms on for quiet some time now but I haven't torqued the control arm shafts yet. I have looked on here several times trying to find the answer to my questions but I am out of luck.
So here's my questions..... Is there a specific torque spec? Is there a specific order I need to tighten them in? Do I need weight on them, or no weight at all? Does it need to be at ride height? Thanks in advance, Adam
Adam '71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. |
12-29-2008, 06:07 PM | #3 |
Re: Help!?!? ART Strong Arms
I installed mine w/weight on the suspension & tightened them to the OE recommended specs in my Chiltons manual.
12-29-2008, 06:32 PM | #4 |
Knuckle head
Shane,
I feel like a dipstick now. The simplest solution, call ART, and I didn't even think of that. Heck, I was on the phone with Tony two weeks ago and it never even crossed my mind to ask him about that... If you have a "Bonehead Of The Month" award can I nominate myself? I just got of the chat with a fellow from ART and he said to tighten them at ride heigt, both front and rear nuts equally until I get the oem troque specs for a 73-87 LCA... Thanks, Adam
Adam '71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. Last edited by AJohn6; 12-29-2008 at 06:50 PM. Reason: Update |
12-29-2008, 07:33 PM | #5 |
One day...
thats ok we all have our blond moments
12-29-2008, 07:44 PM | #6 |
Yo Adam,
If that's the worse that ever happens then I have ya beat when it comes to bone head moves! |
12-29-2008, 10:43 PM | #7 |
if you are talking about the lower control arm u bolts, just make sure you know if you have the thinner or thicker(later model) ubolts. The torque specs are quite different between the two.
12-29-2008, 10:57 PM | #8 |
67-72 parts collector,…
Can someone post these torque values when they find out? I'm interested in what they are.
Thanks.
12-30-2008, 02:16 AM | #9 | |
Knuckle head
I will post it as soon as I find out what they are.
12-30-2008, 06:22 PM | #10 |
Knuckle head
I looked in a Haynes service manual today and it recommended 70 ftlbs of torque for the control arm shaft. I can't remember what it said for the u-bolt but 45 ftlbs sound right, but I am not certain.
12-30-2008, 06:32 PM | #11 |
Junior Member
off the top of my head I cant remember either.... I will check out my manual when I get home too if you guys still need it.
12-30-2008, 07:20 PM | #12 |
its 115 ft lbs. See attached doc.
12-31-2008, 01:00 AM | #13 |
Knuckle head
Wow, jlaird thanks. Your build is the first one I looked at on this site. Thanks for the inspiration I needed to bag my truck, and the help with the torque specs.
Adam
12-31-2008, 09:16 PM | #14 |
glad I could help!
01-03-2009, 11:19 PM | #15 |
Señor Member
Those bolts are supposed to be tight?
